Go to Post Mentors are here to guide and explain not to decide and do. - Fe_Will [more]
Unread 15-04-2003, 17:35
computhief263's Avatar
computhief263 computhief263 is offline
Battlecry...Here We Come!
AKA: "The Freshman"
#0263 (sachem aftershock)
Team Role: Operator
computhief263 is on a distinguished road
Send a message via ICQ to computhief263 Send a message via AIM to computhief263 Send a message via MSN to computhief263 Send a message via Yahoo to computhief263
Wink project 4 next season
by any chance does any one know where i can get specs on last years bosch motors, the fisher pricemotors,globe motors or segways
does any one know wut the abbreviation mNm stands for in terms of load of a motor
Tom "40Watt" Bigelow
Team Electrical/Court Jester
Proud creator of The dongle that nuked the OI, Dj in a bag, and THPD(strobe lights, a hat, a modified flashlight bulb, and a 12v B&D Firestorm™ flashlight make a good combo!)
Unread 15-04-2003, 17:49
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
A Newton-metre is equivalent to 0.7375621 foot-pounds. I assume a mNm refers to a milli-Newton-metre, a thousandth of a Newton-metre. In a motor I think this refers to torque.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 15-04-2003, 19:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
www.team696.org/motorspecs.html
Unread 16-04-2003, 01:43
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Sandrag -
Did the motor performance specs on that spreadsheet come from actual measurements, theoretical calculations, or manufacturers specs? I ask because some of the numbers are suspect. Specfically, the free current ratings for the Bosch motors don't even come close to anything we saw when actually measuring currents.
The Bosch motors supplied this year are heavily biased for forward timing in the windings. We measured over a dozen different Bosch drill motors with a digital meter during the course of the season. When running under no load in the forward direction, we saw currents of 0.6 to 1.2 amps. However, when running in reverse we measured between 5.1 to 5.8 amps, based on the motor.
The 2.5 amps noted in the spreadsheet may be an attempt at an average value between forward and reverse. But it is probably not indicative of actual performance. That would also call into question the speed and torque values, unless these were actually measured values.
-dave
Unread 16-04-2003, 09:31
Dave,
That is way more testing than we did. Do you have any data in a file you can send along? I would be very interested in the trends between motors running FWD and REV. Anything would be helpful.
Thanks,
Unread 16-04-2003, 20:32
Those are the specs for the 2002 motors (and the van door from '01). As far as I know the Chiaphua and Globe specs are the same as this year.
We have not done any testing of our own. All the specs came from the Joe Johnson motor spreadsheet.
Unread 17-04-2003, 16:48
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: project 4 next season
So, what are projects 1 through 3?
Unread 17-04-2003, 17:06
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: Re: project 4 next season
Hehe, he oes that a lot, fair warning, also can anyway tell me how to find out how much power I can generate by spinning the different motors under an alternative power? like a generator?
Matt Krass
Unread 17-04-2003, 19:20
AKA: "The Freshman"
Team Role: Operator
Unhappy team project
i was wondering if any team thats not using the 2003 fischer price motors would be willing to trade them to team 263?
A report on off season competitions Ken Leung Off-Season Events 2 17-10-2003 13:30
Preseason project AdamT General Forum 4 09-09-2002 00:52
Getting ready for the next season Eugene General Forum 9 25-07-2002 11:25
MS Project Build Schedule joe_balint Technical Discussion 1 07-01-2002 03:25
