Go to Post As you get more into your years in FRC, you start becoming friends with more people. You should try it out. Robotics people are pretty nice. - [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
  #34   Spotlight this post!
Unread 18-09-2016, 21:23
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: Putting all the hints together (FRC)
I decided to make a spreadsheet listing the detailed characteristics of the past FRC game pieces, 1992-2016. I also posted this in "2017 Game Speculation". There are some patterns visible here. Spheres are the most common game piece shape, while cylinders are the least common. "CIR", "CYL", "SQ", and "TRI." are abbreviations for "circle," "cylinder," "square," and "triangle" respectively. If the filler is labeled as "air", it means that the game piece is filled with air at pressure higher than that of the ambient air, i.e. inflated(soccer balls, tubes, etc.).
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
