Re: 9179 off season project tacodile
-yes i see that it picked up 2 balls it wasn't driven by the driver and it is the exact same intake that was ran on 179 (financial simplicity) so no concern it can only just fit 2 balls you can see near the end it had a hard time intaking the 2nd one -the firing is a 148 stile 2 position catapult w/ hooks to catch for the short shot and a hard stop for the far aka string. ran by surgical tubing as the power and a cim to retract (orange strap) and held down by a pneumatic piston, the cim would unspool to then fire by said piston |
![]() ![]() Last edited by Max Boord : 09-19-2016 at 02:26 PM. |
Hi, looks like a great bot. Love the climbing mechanism...
Do you happen to have detailed pics of the 179 robot for Stonghold? I'm particularly interested in the climbing mechanism. How does it extend for example? Thanks |
The climber on the in season robot is a 1x1 frame that pivots off the intake. the pivot points are the same as the unused ones on tacodiles intake as 9179 uses the plates that the 179 robot was using in palmetto. At the rear of the intake pneumatic pistons extended into the climber 1x1 tubes holding the climber down. when we go to climb the pistons are retracted and springs and surgical tubing cause the climber to flip up. The cord that dangles down is normally velcrod to the top of the hanger arm and is released by the force of the climber frame extending up. To retract the whole thing the cord spools onto a pipe powered by a PTO off of the drivetrain.
How did you gauge the length needed for the hooks on the catapult? Was it just prototyped, or did you do something else to determine it?
Awesome robot as always. You never stop impressing me. This would have been an extremely competitive robot during the season. Good luck at your events! |
#7
It looks like it's just a flashlight and no vision tracking, is that right? If so you have very good drivers, lining up with a flashlight took 229 a lot longer than that.
#8
we started with a wood model that was darn close to the real thing and yes no camera tracking |
#9
This looks great. Color me intrigued. I can see the purple hooks that you're using to hold down your catapult, but what are you latching onto for the short shot? Are you hooking onto those white pegs under the catapult arm? Where's the hook those catch on?
#10
![]() The intake automatically lifts up when the robot detects it has a ball so its actually rather difficult to pick up multiple balls. The auto lift is still being tuned a little as it sometimes dosn't detect heavily worn boulders or boulders with chunks taken out of them. Both should not be issues on a real field as some of the boulders in our shop are well past the point where they would be taken off the field. Last edited by Max Boord : 09-19-2016 at 11:23 PM. |
#11
I love the alligators sitting in the office chairs... so random.
Awesome work on this! |
