Go to Post Being called coach for the first time by some of my team. My dad was a football player and when I told him that story he teared up a bit. Me? A Coach? - MysterE [more]
  #39   Spotlight this post!
Unread 09-19-2016, 09:19 PM
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Re: What COTS parts would you like to see?
Originally Posted by Oblarg View Post
I designed (and 4464 constructed) a gearbox like this a couple years ago, and it was indeed fairly convenient. The only problem is that it is less-conducive to WCD-style drives, since you need to support the output shaft separately.
Why would that be difficult? Center wheel supported by hex shaft in bearing blocks, same as per wheels. Hex bore gearbox then slips over hex shaft on the inside of the frame.
If you're really clever, you could put the gearbox on a fourth jack shaft between wheels, and reverse the mounting so that the mounting bolts are accessible, and the gearbox slides off the shaft outward from the frame, same as the wheels. That would be amazing!
