Go to Post Well, there goes my strategy of blowing out the opponent and then committing flagrant safety and sportsmanship violations to keep the margin close :D - Jared Russell [more]
Unread 16-09-2016, 12:49
Ringo5tarr's Avatar
Ringo5tarr Ringo5tarr is offline
AKA: Lake Hall
FRC #1764 (Liberty Robotics)
Team Role: Electrical
Rookie Year: 2015
Ringo5tarr will become famous soon enoughRingo5tarr will become famous soon enough
Ultrasonic Sensor Question (FRC+VEX parts)
My team is looking to upgrade our sensors to assist manual shooting before our offseason event, we used to have two Ultrasonics taped on (the whole electrical was real janky), both of which have been completely rekt and couldn't successfully help due to a lack of programming time. So I'm looking for Ultrasonic sensors we can use, mainly I'm asking if it's possible to use VEX rangefinders, since we already have a decent amount as is. I heard that they can give bad readings and can be fried with too much vibration. Is this true? And how difficult is it to wire up and program (compared to other ultrasonics)?
Unread 16-09-2016, 17:27
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Ultrasonic Sensor Question (FRC+VEX parts)
I think your first step involves deciding the range you want the sensors to work over, and then comparing that to the sensor specs.
If the VEX sensors you have aren't well-suited for your job, take a look at MaxBotix, their website has good specs for their products, and some of my colleagues had a good experience using a MaxBotix sensor (in a *friendly* environment, not on an FRC robot ...).
Blake
Unread 20-09-2016, 13:19
arichman1257's Avatar
arichman1257 arichman1257 is offline
VP, Control Systems Captain, Coach
AKA: Alan Richman
FRC #1257 (Parallel Universe)
arichman1257 is on a distinguished road
The Parallax ping sensor is very easy to use on an Arduino but not so much on a RoboRIO. So if you have them lying around try not to use them for FRC. They're a pain. The kind we use whenever we use an ultrasonic sensor is 5 pins. It's either an SRF04 or 05. They're easy to use and program on an FRC robot. here's a link https://www.robot-electronics.co.uk/htm/srf05tech.htm
Volunteer Roles:
Soon to be!
Team Roles:
1257 Parallel Universe: 2014 - 2017 Seasons
2017: Vice President, Control Systems Captain, Drive Coach
2016: Control Systems Captain, Operator, Dean's List Semi-Finalist
2015: Control Systems, Operator
2014: Programming/Electronics Apprentice
