Go to Post I, as a programmer, always strive to have the entire robot operate with as little driver input as possible. Those pesky humans.... - dellagd [more]
Unread 15-09-2016, 08:24
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: custom button panel
I've used this Adafruit Bluefruit EZ-Key - 12 Input Bluetooth HID Keyboard Controller at about $20.
You wire up switches to the board. It connects to the laptop via Bluetooth. You can program the board to be a sudo keyboard with any key chord combination you want. (ie a,A, ctl-A, Alt-A, ctl-shift-alt-A, etc. )
You can use any kind of switch. There are places you can get joysticks with switches on the axis.
Not sure what the FRC rules are around bluetooth keyboards.
I've used these to make a wall button setup that talks to a home control computer, fun box for the grandmuchin, and working on a Kerbal Space Command console.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 15-09-2016, 09:24
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
I've been working on a project for this. Team Fusion has been using this for several years and I made a new revision that fixed a few issues for Garnet Squadron.
Currently I'm working on taking LabVIEW out of the equation and relying on Python and the wxPython extension.
Essentially, the board is an Arduino Mega 2560. The only special chip is the LED driver, which is a constant current driver made for driving LEDs. I have the output set at 20mA, which is very common with LEDs. It's easy enough to change though.
Here's the control board Garnet Squadron made for this year's robot:
Finally, below is the Python code in action. I'm currently working on a simulator because lets face it... I don't want to carry around the driver station everywhere I go.
The good news with the simulator is it works exactly the same as the real board. You can unplug/plug it in and toggle every input as well as see every output. Furthermore, since it works exactly the same as the real board, you can use the simulator to control the robot, or your simulated robot. The simulated robot with simulated button panel is where this can really shine.
This code isn't finished yet, but when it is, the GUI will not be shown by default. Instead, there is a taskbar icon that indicates the status of the control board. Green means good; red means bad.
Is this in mass production? No... I need to tweak a few more hardware things. For basic inputs such as switches and potentiometers and with LED outputs, it's great. There are some problems with running servos. They're interfering with the analog inputs. All the design files and software are in our repository here.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 15-09-2016, 10:17
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Bluetooth is illegal within the arena. See this rule:
Originally Posted by R95
Other than the system provided by the ARENA, no other form of wireless communications shall be used to communicate to, from, or within the OPERATOR CONSOLE.
Examples of prohibited wireless systems include, but are not limited to, active wireless network cards and Bluetooth devices. For the case of FIRST Robotics Competition, a motion sensing input device (e.g. Microsoft Kinect) is not considered wireless communication and is allowed.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 15-09-2016, 11:23
Thanks! So many rules, it's hard to remember what's in and whats out, thanks for taking the time to do the research and posting the rule.
Unread 15-09-2016, 12:27
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Interesting product, from a company I've not heard of yet. One concern, there doesn't seem to be many button inputs. If you do a autonomous switcher, that can be 5 inputs all by itself. Is there any way of increasing this? Also, do you have any way of doing the outputs in WPIlib like the MSP430 can?
Option A: Use an encoder to convert a given value to binary and read the buttons as a binary input.
Option B: Use analog input on "joystick" and just break it up into ranges.
Option C: Put the control in software on the Driver Station Dashboard and the robot doesn't start auto until it receives its directions.
We typically use Option C, particularly as we had at least three different settings to configure each match (goal, position, defense).
Unread 15-09-2016, 12:54
RyanN's Avatar
RyanN
Option B works really well. Wire GND to the left most position and 5V to the right most position. Put resistors in series between each post of the other positions. It'll make it like a potentiometer, but with low resolution.
Say you have a 6 position switch, you would wire it like:
GND-> Position 0 - 2kOhm - Position 1 - 2kOhm - Position 3 - 2kOhm - Position 4 - 2kOhm - Position 5 <- +5V
Then connect it to the joystick input. I guess it goes from -1 to 1, like shown below:
Pos 0 -> ~-1
Pos 1 -> ~-0.6
Pos 2 -> ~-0.2
Pos 3 -> ~0.2
Pos 4 -> ~0.6
Pos 5 -> ~1
You'll want to factor in some tolerance. It won't be exactly -1, -0.6, etc. In this case, you have 0.4 units between each measurement. You can test between the cases.
if ana < -0.8
pos = 0;
else if ana >= -0.8 and ana < -0.4
pos = 1;
else ifana >= -0.4 and ana < 0
pos = 2;
else ifana >= 0 and ana < 0.4
pos = 3;
else if ana >= 0.4 and ana < 0.8
pos = 4;
else // in this case, this has to be true: ana >= 0.8
pos = 5;
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 15-09-2016, 14:07
One Eyed Man
You can also calibrate the software to the actual values measured. Since this isn't going in the bag this shouldn't be an issue.
Unread 15-09-2016, 15:40
ttnn58 ttnn58 is offline
FRC #4586
ttnn58 is an unknown quantity at this point
immpressive!
ye olde kaboom XD
but i am not looking for something so complicated, i just want to simpify the controls for the operator, because the joystick is sometimes making a lot of headache.
i will porbably use an arduino with unojoy, and if it won't work i will use the msp430.
i want to use the arduino IDE because i am not a programmer myself (and i do not wish to be XP) and this is the easiest way i can make this work.
can i contact you if i will have difficulties with wiring/programing?
thanks!
Unread 15-09-2016, 17:16
RyanN's Avatar
RyanN
Originally Posted by ttnn58 View Post
immpressive!
ye olde kaboom XD
thanks!
You absolutely can. You could probably reuse most of my Arduino code as well. The computer software isn't completed yet, but you're more than welcome to try it. It's fully functional and can be used right now, but it lacks configuration for the robot address or test functionality to drive outputs without the robot.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 16-09-2016, 08:06
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
We use a keyboard emulator called PoKeys. https://www.poscope.com/products/pokeys-devices/
It's been really easy to work with as you assign values to keyboard keys you wouldn't normally use. Also, if the control panel happens to fail, the operator can make use of the keyboard in an emergency.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 18-09-2016, 16:03
Here are some pictures of our panel:
Andrew Basse
Unread 20-09-2016, 09:48
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
It seems like a good time to post our minimalist custom control solution.
https://github.com/frc4646/lightswitch
Unread 20-09-2016, 12:38
FRC #4586
Originally Posted by bobbysq View Post
is the arduino connected to your computer? how? any special software?
the power to the light is from an external battery, or the robot battery?
can i use this method to control the movement of the robot?
Unread 20-09-2016, 15:30
Rookie Year: 2015
The Arduino is connected to the driver station off camera. No special software except for the gamepad library. The light is a 12v bike light (here at Andymark but you can get a cheaper generic version) attached to a VEX Spike relay on the robot. You could, in theory, control the robot with this, but I doubt a light switch will be better than a joystick.
