Re: R Package for Downloading FIRST API Data
Good job sirwin on the code, and an even better write up of how you did it. |
With respect to speeding up the calculation, I had a thought.
It takes my algorithm 9 seconds to produce the 2696 x 2696 A matrix -- but updating the A matrix with new match data should be nearly instantaneous. For every new match, we just have to add 1 to 18 different elements in the A matrix (all other A matrix elements will remain unchanged). Each element of the a matrix is directly accessible by team numbers. So it takes 13 seconds to calculate world OPR from scratch, but as long as we retain the A matrix, it should only take about 5 seconds to update world OPR with new match data. That's 2 seconds for updating the A and B matrices and 3 seconds for solving for OPR. Of course, this is assuming that R's underlying C code doesn't do anything stupid, like extracting an array element by going through every array element until it gets to the right one. Also, the A matrix would need to be maintained in memory -- disk access would slow things down. |
Ax = b .. overdetermined system of linear equations (has no exact solution) N = A'*A d = A'*b Nx = d .. linear system of normal equations (whose solution is the least squares solution for Ax=b) |
OK, I was being generous. Cut it by a factor of 10. Seriously.
If there is any interest in learning how to do this within the R community please let me know and we can work it out together.
I took the world OPR data and made a graph.
EDIT: I made a better graph. Last edited by Joey1939 : 25-10-2016 at 15:41. |
#7
Downloadable firstapiR Packages
I've had a request for a downloadable version of the firstapiR package, so that there is another option for obtaining firstapiR that doesn't require the devtools package and installing from github. I've made both a source and binary version of the package available at this website.
The file downloads are hosted on my MediaFire account. I apologize for the adds, but I didn't want to post publicly available links to cloud drives where I keep personal files (and I'm too cheap to pay for add-free downloads ).Stacy |
#9
I created version 2.0.0 of the firstapiR package for downloading and manipulating FIRST API scouting data using the R language.
Here's a link: http://irwinsnet.github.io Once I started using the package to do OPR calculations, I realized it needed some improvements, specifically in how the data frames are shaped. Stacy Irwin |
#10
@ Stacy: thanks for posting this. I just send you a PM. |
#11
, but using unmodified Sirwin's code I am getting ~12 seconds with an i7-6560U (2.2GHz) and 8gb of RAM, memory usage is low so we can eliminate that as a factor. The bottleneck is (unsurprisingly) CPU clock cycle speed. I'm using firstapiR v2.0.0 Skye Leake |
#12
I obviously am doing something not quite right... |
#14
Your results look about right for R code that uses dense matrix technology.
https://www.chiefdelphi.com/forums/s....php?p=1612297 https://www.chiefdelphi.com/forums/s....php?p=1612581 https://www.chiefdelphi.com/forums/s....php?p=1613118 https://www.chiefdelphi.com/forums/s....php?p=1614125 Last edited by Ether : 31-12-2016 at 22:09. Reason: added links |
#15
In case anybody wants to learn R, here is a great way to get introduced http://swirlstats.com
Last edited by Conor Ryan : 01-01-2017 at 11:51. Reason: It's what we use when building models! |
