Go to Post I think we need to take away your hammer privileges. - Katy [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 24-09-2016, 12:25
LED bulb question
Two different LED bulb models by the same manufacturer. Packaging says:
bulb1: 800 lumens, 2700K, 150 mA @ 120V, 8.5 watts
bulb2: 800 lumens, 2700K, 120 mA @ 120V, 10 watts
Can someone explain what's going on here?
Unread 24-09-2016, 14:08
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Re: LED bulb question
The two bulbs might operate at different power factors (PF).
Power factor is defined as the ratio of power (Watts) consumed to apparent power (Volt-Amperes) drawn. Resistors and old-fashioned incandescent light bulbs operate at unity power factor, because all the current they draw follows the applied voltage instantaneously; no lag, no distortion. Inductive loads such as transformers and AC motors operate at less than unity power factor because their current draw lags the applied voltage. Electronic loads, such as the AC to DC converter circuits inside LED light bulbs, operate at less than unity power factor because their current draw is distorted relative to the line voltage. But, not all AC to DC converter circuits are created equal; some distort more than others, so some operate at lower power factor.
The first bulb in your example operates at PF = 8.5 / (120 x 0.15) = 0.47
The second bulb operates at PF = 10 / (120 x 0.12) = 0.69
It would be worthwhile to test these two bulbs using an inexpensive meter such at the Kil-A-Watt, to see how well actual performance tracks their markings.
Richard Wallace
since 2003
Unread 04-11-2016, 10:04
Hey Richard,
I picked up a Kill-A-Watt yesterday.
I tested it with a standard* 60 watt incandescent bulb in an outlet whose voltage reads 123.6 V. The Kill-A_Watt says it's drawing 33.9 watts / 33.9 VA (PF=1) and 0.27 A. I had not expected that.
Would you please test a standard* 60 watt incandescent bulb with your meter?
* i.e. not "long life"
Unread 04-11-2016, 22:37
Will do that. Right now I am on the road coming back from New Hampshire, so it may be late Saturday before I can post again.
Richard Wallace
since 2003
Unread 07-11-2016, 11:25
I just tested a 750/1500 watt dual heat resistive space heater with the Kill-A-Watt. The readings made sense. Power Factor 1.00 (as expected), and watts approximately 765 (on low) and 1443 (on high).
When I get a chance, I'm going to test a larger sample of incandescent light bulbs of various brands and power ratings.
Unread 07-11-2016, 11:47
I just tested three GE Reveal incandescent light bulbs with my Kil-A-Watt.
The 29W bulb measured 28 Watts, 0.23 Ampere, 1.0 power factor.
The 60W bulb measured 60 Watts, 0.5 Ampere, 1.0 power factor.
The 75W bulb measured 76 Watts, 0.63 Ampere, 1.0 power factor.
As expected.
Richard Wallace
since 2003
Unread 07-11-2016, 12:25
I don't have any GE Reveal here, but I tested a bunch of GE Soft White incandescents and they all measured roughly half their wattage rating (with PF=1.00).
Do you have any GE Soft White bulbs? If so, could I ask you to test them?
Unread 07-11-2016, 13:27
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
What about the LED bulbs that started this discussion, have you tested them? Inquiring minds want to know.
I do have to wonder if there is a problem with Ether's Kill-a-watt in accurately measuring at the lower end of the range. I was under the impression that the difference between the standard, soft white and reveal bulbs was purely the coating on the inside of the glass and not due to a different filament. So in theory they should all match their wattage ratings within the expected tolerance of a high volume mass produced item at low price point.
How about plugging a power strip in with that heater on low and a lamp with the bulb and comparing the results with and without the bulb on?
Unread 07-11-2016, 13:47
Thanks for the excellent suggestion.
34.2W bulb only (60 watt soft white incandescent)
755W heater only
811W heater plus bulb
811-755 = 56W
Power Factor was 1.00 for all readings above.
Spec accuracy is listed as 0.2%
I think I may have a defective unit.
Unread 07-11-2016, 15:45
Mr V's Avatar
FRC #5588 (Reign)
I was thinking about the bulb's tolerances, but the Kill-a-watt's tolerance is an important part of the equation as well.
Is there anything in the documentation that would indicate the tolerance is different at different parts of the range? If it is just a stated .2% then I'd have to agree that you seem to have a defective unit based on Richard's results with his. +/- 1 Watt seems to be as good as would be expected on a product like an incandescent bulb.
Unread 07-11-2016, 16:17
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Have you tried measuring the bulb resistance with a DVM?
Unread 07-11-2016, 16:38
The max watts spec for the unit is 1800W.
So even if 0.2% means 0.2% of 1800, the unit is still way out of spec.
Unread 07-11-2016, 17:34
Richard, If you are still following this thread, could you please take a peek at the label on the back of your Kill-A-Watt and compare it to this and flag any differences for me? Note especially the red arrows.
I'm wondering if your unit is an improved version.
I bought mine at Menard's, and they appeared to have been hanging on the rack for quite some time (packaging covered in fine dust). Also, the printing on the cardboard label inside the thermal-welded plastic packaging is copyright 2011.
Unread 07-11-2016, 18:48
DonRotolo's Avatar
Back to humble
FRC #0832
Data point: My Kill-a-watt is wildly inaccurate at very low (< 10W) power levels: Some of my light bulbs don't even register any reading. (This is based on measurements more than a year ago. I should try to repeat them now).
Unread 08-11-2016, 07:52
Mine is older than yours. Model 4400, yours is Model 4400.01
Mine is also marked Conforms to UL STD. UL 3111-1, yours is 61010-1
Mine is marked Voltage: 125VAC Power: 1875VA, yours is 120VAC, 1800W
Richard Wallace
since 2003
