Go to Post I would proudly put an AndyMark sticker on our robot any day! - Andy Grady [more]
Unread 24-09-2016, 08:38
YPetcho YPetcho is offline
FRC #2230
YPetcho is an unknown quantity at this point
Motorizied flow control
Hello
I came up with an idea to control the speed of a piston and use it with precision and i wanted to make sure its legal.
we bought 5 ports - 3 position valves so we could stop the piston at any position we want, but we had a problem, the piston is moving too fast for the drivers to control it well.
so i attached flow control tubes to the relief ports in the valve
http://www.andymark.com/product-p/am-2690.htm
its worked well but if we wanted to open the pistons fast we couldn't do so.
so i connected a hobby servo with a gear ratio to the screw on the flow control tubes so i can control the speed of piston with driving.
is this legal?
tnx in advance
Unread 24-09-2016, 09:36
Re: Motorizied flow control
To be honest, while I cannot recall a rule against doing so, a setup like that would have me asking the LRI for advice.
If you have a reason to use such a setup in the regular season, please ask the official Q&A as early as possible--and then bring the answer to your events, just in case your LRI hasn't read that particular Q&A.
Unread 24-09-2016, 12:19
Chris is me's Avatar
AKA: Pinecone
I don't understand why this would invite any rules scrutiny at all. What rule does it even potentially violate?
Unread 24-09-2016, 13:05
FRC #2230
as written in rule R77-F in this year's game:
"F. Pressure transducers, pressure gauges, passive flow control valves (specifically “needle
valve”), manifolds, and connecting fittings"
as u see its written passive flow control valves, so i dont know if it counts as an active or passive one.
Unread 24-09-2016, 13:09
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
We had a team pass with something similar at Waterloo, the LRI and I couldn't find anything illegal about it. As long as the pneumatic fitting remain unmodified It should be fine. I would still consult the Q&A as the ruling of inspectors could vary and It could potentially save some time during inspection.
2016: FRC 865 Mentor
2017: Free Agent Mentor, Ref, Inspector
Unread 24-09-2016, 13:39
AKA: Pinecone
The valve itself is passive, a custom system actuates the passive control, that is completely separate from the pneumatic system. The pneumatic components are, presumably, unmodified. Seems like it should be good. It's just unconventional.
Unread 24-09-2016, 16:29
Hello
When you use your 5 port 3 position valves to stop the piston half way, does your pneumatic system comply with R89?
R89 Any pressure vent plug must be:
A. connected to the pneumatic circuit such that, when manually operated, it will vent to the atmosphere to relieve all stored pressure in a reasonable amount of time,
Unread 25-09-2016, 00:36
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
The rules problem isn't with the throttle valve, it's with the 3 position solenoid valve. AFAIK, the pneumatic system is supposed to completely depressurize when you open the vent valve. A 3 position valve in the "locked" position would prevent that.
Edit: or what Joe said
Unread 25-09-2016, 01:02
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Dare I ask what this was for?
Unread 25-09-2016, 01:29
mman1506's Avatar
no team (WARP7)
The team wanted to have a 3rd position for their air cylinder. I think the plan was to actuate the cylinder with the solenoid and use the servo to let out air until it was the right height. I don't think they ever got it functioning.
Unread 25-09-2016, 22:38
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
As already mentioned the problem with your system is not the flow controls, but the 3-position valve.The question of using a 3-position valve to achieve intermediate cylinder positions has come up many times. If the center valve position is both-ports-closed, this technique is illegal because it creates closed, pressurized lines that are not vented when the system is vented. If the center valve position is both-ports-exhausted, this should be legal, but would have no ability to hold its position on its own.
Unread 26-09-2016, 10:44
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
It is a little Rube Golbergish, but there is a way to make a closed center 3 position valve legal under 2016 rules. You use check valves to allow both sides of the cylinder to flow back the working pressure side of the system. They won't do anything when the system is pressurized, but they will vent the cylinder when the system is depressurized.
Unread 29-09-2016, 12:43
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Attached is a sketch on how to use check valves to make using a closed center 3 position valve legal under FRC rules (at least for 2016)
Unread 29-09-2016, 13:21
Levi Madden's Avatar
Levi Madden Levi Madden is offline
Student
FRC #1987
Levi Madden is on a distinguished road
It is important to note that you connect the check valve to your working pressure, not your stored.
Unread 29-09-2016, 14:09
AKA: Brendan Simons
FRC #5406 (Celt-X)
Oh very cool, thanks! With a setup like that you could create a pneumatic position control system (like http://www.bimba.com/Products-and-Ca...ntrol-System/). Add a pneumatic rod lock (http://www.bimba.com/Products-and-Ca...Line-Rod-Lock/) and you could move and hold actuators with very few mechanics.
The downside is the limited compressor size means you wouldn't be able to move a cylinder bigger than ~1" more than a few cycles a match.
