Go to Post Not even close to ready...can we delay it till like...January 2010? - Cory [more]
Unread 23-09-2016, 17:43
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Re: Does the RoboRio have mounting holes?
You might try these screws. Pretty cool looking and easy. But, that price ....
For most situations I would just go with zip ties, as shown on pages 25-29 of the doc that ollien linked earlier: http://www.ni.com/pdf/manuals/374474a.pdf
Richard Wallace
since 2003
Unread 23-09-2016, 21:20
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Originally Posted by messer5740 View Post
Oh well that's exactly what we use we just call it Velcro where I'm from
Dual-lock is quite different (and better IMHO) than Velcro. The key advantage is that there is only one "type" so you can't stick the wrong stuff on one side. You also don't run out of one type and have loads of the other.
Also it "clicks" together, rather than mooshes like Velcro. It's great for electrical, i use it on just about everything electrical that has a flat bottom, including the RoboRio. McMaster #94935K43 is what we usually get.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 23-09-2016, 23:47
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We used the screws this year and had several of the inserts come out of the plastic moldings. We had holes made in the belly pan for zip ties as well and just reverted to those after we started having issues.
Unread 26-09-2016, 11:14
The threaded holes are perfect for mounting the RoboRIO to a custom plate with attached strain relief.
Unread 26-09-2016, 11:20
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
a little bit of googling, with a small detour, brings us a picture of the bottom of the roborio.
http://www.team358.org/files/program...stem2015-2019/
scroll down a little ways
Unread 26-09-2016, 17:04
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
We're not seen that in our testing, nor have I seen any RMAs as a result of this, but the screws do use inserts, and given enough force will pop out so I believe you!
With roboRIO you have a variety of mounting options, so use the one that best suits your installation.
Meanwhile I'll keep an eye out for popped inserts - thanks for the report!
Unread 26-09-2016, 17:19
Engineering Coach
We are pretty skilled at breaking things in interesting ways. Next time we pull it off the robot we'll take photos of the missing thread inserts and how we were mounting it.
Unread 26-09-2016, 18:53
kylemikableh's Avatar
kylemikableh kylemikableh is offline
FRC #1672 (Robo T-Birds)
Rookie Year: 2016
kylemikableh is an unknown quantity at this point
I suggest using both the Velcro and zip ties, its always good to have a back up incase one breaks.
Unread 27-09-2016, 09:03
AKA: Chris Rake
no team (Athena)
Thanks! I'd love to see it!
Unread 27-09-2016, 10:15
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
One failure mode with the screws might be over-tightening them initially and pulling the insert out.
Unread 28-09-2016, 07:47
Engineering Coach
That seems like a likely cause.
