#16
Re: Tell Me About Your Pit
2876 is pretty proud of its pit (https://pbs.twimg.com/media/CgLem7rUUAA5_4E.jpg:large).
The five most important things in the pit are 1. Empty space for the robot and pit crew members 2. Table space for tools, programming etc. (the shop in the box we have has table space and a vice on it)- we also use large boxes for bringing in batteries and materials so that we can use that as table space. 3. Designated areas and enough (but not too much) mechanical, electrical, and programming supplies. 4. Designated areas for safety and strategy equipment that the entire team is aware of and has access to. 5. Banners and displays to make the team visible and exciting (and buttons/giveaways in the front corner so they don't interfere with robot transport and maintenance) |
#17
Pits only function if they are clean and organized. Here's a slightly different take on the list. (I stretched the top 5 a bit.)
1. Empty space. Git rid of tables unless you plan to do major upgrades or build something. We use our cart as a temporary table if needed. Otherwise, table tops attract junk. We also use the competition machine shop and only bring hand tools. 2. Robot cart. You need a cart anyway, so make it a functional part of your tool storage system. 3. Rolling battery charging station. Make a compact battery charging station for you robot batteries and hand tool batteries. It needs to roll if you plan on going to the playoffs. 4. Rolling tool boxes with a vise. Limit the amount of tools needed by having standard fasteners. 5. Spare parts / raw material system. We have small parts organizer boxes for fasteners and control system spares. Raw stock is in a bin attached to the side of the tool box. 6. Task lighting. 7. Branding system. David |
#18
The pit that we use was built in 2012. we have used it ever since then and it has worked great for us. We have 4 cabinets mounted on the back wall above 4 tool chests that hold all of out tools. On one wall we have rack that holds 6 tool belts that drive team and pit crew members can use for matches in case a quick repair or something is needed. We also have a rolling cabinet we made that has 6 built in chargers and an outlet to plug in two more portable ones. We also have 2 computer monitors mounted to the front of our pit that we can plug a laptop into for things like out match schedule.
edit: We also built in a big power strip so that we have 8 outlets all around the pit. One of the other things about the structure is that the upper halfs of all the walls are pegboard. We use this to store anythings from files to extension cords. Super useful. Last edited by lark95 : 26-09-2016 at 13:02. |
#19
After working on this year's pit I have realized its importance for:
- Charging Batteries - Robot fixing - Presentations for judges - Team morale! So I would say: 1. Good and reasonable space managment 2. Batteries charging dock and easy-access-but-not-interrupting storage 3. Easy-access-but-not-interrupting storage 4. Team resources for explaining about the team and the robot 5. Safe working space *looking for a good picture of our pit, will upload soon |
#20
Ignoring the robot, people, and the driver station, the five things that I believe are necessary for our pit are (in no particular order):
Note: My comments are my own and may not represent the teams that I am involved with. |
