Go to Post The competition is over, I have no other FIRST-related activities to pursue–WHAT ELSE AM I GOING TO DO WITH MY LIFE BUT BROWSE CHIEF DELPHI UNTIL JANUARY???? - David8696 [more]
Unread 26-09-2016, 11:36
Alicia V Alicia V is offline
FRC #2046 (Bear Metal)
Team Role: Electrical
Alicia V is an unknown quantity at this point
Using Talon Sr
So as an off-season project, I am wiring up a chassis for prototyping. We have a ton of Talon Srs (the older ones) to use instead of the Talon SRX. The plan is to put encoders on the drive train and have pneumatic shifting.
I am wondering how to wire up using the newer electronics system and CAN bus without motor controllers that run through CAN.
How should I go about doing this and how can do I wire CAN?
Any other advice would be helpful
Thanks all!
Unread 26-09-2016, 11:45
Chris is me's Avatar
AKA: Pinecone
Re: Using Talon Sr
I do not believe the old Talon SRs supported CAN? Someone correct me if I'm wrong, but I thought they were PWM only.
Unread 26-09-2016, 11:54
viggy96 viggy96 is offline
FRC #3331
viggy96 is infamous around these partsviggy96 is infamous around these parts
Re: Using Talon Sr
The Talon SR, does not have CAN bus capability. It can only be controlled via PWM.
Unread 26-09-2016, 13:36
ttnn58 ttnn58 is offline
FRC #4586
ttnn58 is an unknown quantity at this point
Re: Using Talon Sr
older talons can only be connected to PWm..
Unread 26-09-2016, 14:03
Re: Using Talon Sr
What you'll need to do is wire the encoders to the RoboRIO (or your preferred alternate controller) and have the RoboRIO read their data, then make whatever adjustments need to be made to the output to the Talons. As noted, the older Talons don't have CAN, so you'll be using PWM outputs for that.
Basically... you'll be doing it just about the same way as if you were using Spark controllers.
Unread 26-09-2016, 14:10
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Using Talon Sr
If the question is how to wire CAN when you have no CAN motor controllers, it's pretty simple:
If you're using the PCM,
wire roboRIO to PCM to PDP, with CAN jumper on the PDP in the ON position.
else
wire roboRIO to PDP, again with CAN jumper in the ON position.
In both cases, orange to orange and green to green for each leg. Twist the orange and green wires around each other to cut down on RF radiation.
The motor controllers will need PWM cables, available pre-fab from AndyMark or other places, but they're essentially a 3-wire ribbon cable with a male Dupont (0.1" header) connector at one end and female Dupont at the other end. The traditional coloring is black/red/white, as the ground is at one end, voltage in the middle, and signal at the other end. The roboRIO and motor controller PWM ports have indications as to which end should have the ground or black wire.
Encoders will have to connect back to the DIO ports. Quadrature encoders will require two ports each. Search CD for the specific encoder model you are using to figure out the details of this wiring.
Unread 28-09-2016, 08:22
arichman1257's Avatar
arichman1257 arichman1257 is offline
VP, Control Systems Captain, Coach
AKA: Alan Richman
FRC #1257 (Parallel Universe)
arichman1257 is on a distinguished road
Re: Using Talon Sr
If I understand your question correctly then here is your answer:
You can wire up the CAN in the same way that you would normally. Just don't connect it to the motor controllers. It will go from the RoboRIO to the PCM to the PDP.
1257 Parallel Universe: 2014 - 2017 Seasons
2017: Vice President, Control Systems Captain, Drive Coach
2016: Control Systems Captain, Operator. MAR District Championship Winner, MAR Mt. Olive Event Winner, MAR Bridgewater-Raritan Event Finalist
2015: Control Systems, Operator. MAR North Brunswick Event Finalist
2014: Programming/Electronics Apprentice. MAR Clifton Event Winner
