Go to Post There's the problem!! The #1 reason to blame the programmers: They always forget to grease their code. :rolleyes: - Jack Jones [more]
Unread 25-09-2016, 20:06
414cnewq 414cnewq is offline
FRC #3844 (Kentucky Wildbots)
414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of
300 Point Match
Considering that we were unable to witness a 300 point Match at Chezy Champs or IRI, what do you think it would take to attain 300 points in 1 match from one alliance?
Unread 25-09-2016, 20:40
Brian Maher's Avatar
Brian Maher Brian Maher is online now
Questionable Decisionmakers
FRC #2791 (Shaker Robotics), FRC #1257 (Parallel Universe)
Brian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond repute
Re: 300 Point Match
Let's do some math. The following adds to 300 points:
Auto:
3 crossings (30 points)
4 high goals (40 points)
Teleop:
7 crossings (35 points)
3 scales (45 points)
breach (20 points)
capture (25 points)
21* high goals (105 points)
*Everything else adds to 195, so (300-195)/5 = 21
To break 300, you need an absurd (albeit possible) number of teleop high goals, an average of one every six seconds of teleop. In addition, auto/endgame/C crossings have to go perfectly. Put it all together, and while 300 points is possible, it is incredibly unlikely to nail everything in one match.
2016-present, Mentor, FRC 2791 - Shaker Robotics
2016: Tech Valley SF (5236, 2791, 3624) and Quality Award, Finger Lakes SF (5254, 2791, 2383), Battlecry@WPI Winner (195, 2791, 501), Robot Rumble Winner (2791, 195, 6463)
2016-present, Mentor, FRC 1257 - Parallel Universe
2016: Mount Olive Winner (1257, 5624, 1676), Bridgewater-Raritan Finalist (1257, 25, 3340, 555) and Gracious Professionalism Award, MAR CMP Winner (225, 341, 1257), Archimedes SF (4003, 4564, 5842, 1257), IRI Invite
2012-2015, Student, FRC 1257 - Parallel Universe
2015: Mount Olive QF (1257, 1811, 1923) and Industrial Safety Award, North Brunswick Finalist (11, 193, 1257) and Team Spirit and Industrial Safety Awards
2014: Clifton Winner (1626, 869, 1257), MAR CMP QF (1257, 293, 303)
2013: TCNJ Industrial Safety Award
2012: Mount Olive QF (204, 303, 1257)
Unread 25-09-2016, 20:50
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
Re: 300 Point Match
Using IRI rules,
Auto could have three two ball autos on an alliance, so:
Auto:
3 crossings - 30 pts
6 high scores - 60 pts
End game:
3 hangs - 45 pts
Tele-op:
7 crossings - 35 pts
Breach - 20 pts
17 high scores - 85 pts
Capture - 25 pts
A possible dream alliance that I think could pull it off:
179 - Children of the Swamp
1678 - Citrus Circuits
254 - Cheesy Poofs
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
Unread 25-09-2016, 21:28
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: 300 Point Match
Given the proper third partner, 195 and 971 could have had a chance at pulling this off. 195 makes quick cycles through the low bar. 971 has showed they are incredibly strong cycling over the defenses but their strength compared to most teams is their ability to chase down balls in their opponents secret passage before they roll into the neutral zone. They both have the ability to run a consistent two ball auto under the low bar plus a scale at the end.
195, 1114, & 225 came close at IRI with a total of four missed shots in teleop. With 971 instead of 1114 its possible they could have pulled it off.
1058 PVC Pirates 2016 - xxxx
Unread 25-09-2016, 21:40
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Re: 300 Point Match
Originally Posted by Brian Maher View Post
Teleop:
3 scales (30 points)
breach (25 points)
capture (25 points)
23* high goals (115 points)
*Everything else adds to 185, so (300-185)/5 = 23
3 scales is 45 points and a breach is 20 points.
Unread 25-09-2016, 21:44
Re: 300 Point Match
Good catch, fixed my post. I'm used to thinking of scales in terms of their marginal points compared to a challenge, though not sure why I mixed up 20/25, those numbers are engraved in my mind.
Unread 26-09-2016, 17:15
mastachyra's Avatar
Re: 300 Point Match
Going against an opponent who continually drives through the wrong secret passage would help alot too.
Anyone want to watch tons of matches from last year and figure out a "dream" alliance to compete against?
Unread 26-09-2016, 17:27
Edxu's Avatar
Edxu Edxu is offline
Scouting/Strategy Lead
AKA: Edwin Xu
FRC #0610 (The Coyotes)
Edxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud of
Re: 300 Point Match
Auto:
Teleop:
breach (20 points)
capture (25 points)
I don't think that 21 teleop is actually that far out of the question, assuming the pseudo-chokehold scenario with a 3-offense lineup running third bot in and around the secret passage exit, blocking balls from exiting the courtyard, having the best shooter cycle those balls and having the second robot breach the rest of the defenses.
However, this runs the significant risk of being penalized for being touched in the opponent's secret passage, as well as a possibility of being yellow-carded for G25b or G25e. That being said, I think that it's definitely attainable with a good drive team and a drive coach that calls out incoming robots ahead of time, giving the drivers a chance to react.
2013 FRC World Champions (1477, 1241, 610)
Queens University Computing Class of 2020
6-??
Unread 26-09-2016, 23:51
RoboChair's Avatar
RoboChair RoboChair is online now
AKA: Devin Castellucci
Re: 300 Point Match
1678 scored 24(21 Tele, 3 Auto) boulders with 148 and 364 during Quarter finals at Champs. 1678 scored 23(19 Tele high, 1 Tele low, 3 Auto) boulders with 971 and 604 during Semi-finals at Chezy.
More than 20 boulders is certainly possible.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 27-09-2016, 03:14
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Re: 300 Point Match
Match 88 at IRI had 25 high goals, 26 boulders (24 tele high, 1 tele low, 1 auto). You really just need to have the right alliance that doesn't get in each others way. Plus not being defended helps.
Unread 27-09-2016, 08:46
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Re: 300 Point Match
Could a 300 point match happen in a 6v0 situation? Obviously, the courtyard would get a little crowded and it would do nothing in terms of ranking for the other team, but I could see it happening at a small off season for no reason other than to try to break the record.
Unread 27-09-2016, 08:54
roboruler roboruler is offline
roboruler is infamous around these partsroboruler is infamous around these parts
Re: 300 Point Match
But here's the thing, in that case the record could be broken easily but doesn't mean nothing. Perhaps not having defence one match and just letting the alliances do there own thing would be better.
Unread 27-09-2016, 10:10
Re: 300 Point Match
Auto:
Teleop:
breach (20 points)
capture (25 points)
With this scoring scenario, I feel it is completely possible to get above 300 points. However, I would make one modification:
5 auto High goals.
That way, either one robot doesn't have to scale or class C can be left alone.
That way, this alliance could attain 300 points:
254: 8+ teleop high goals per match, a scale, and the only demonstrated 2 ball not low bar in a (semi) official match (CC Quals 41)
195: 9+ teleop High goals per match, a scale, and a consistent 2 ball.
4678: 4+ boulders per match, plus ability to do class C.
Unread 27-09-2016, 11:12
Chris is me's Avatar
AKA: Pinecone
Re: 300 Point Match
5 auto High goals.
There are a lot more robots that can shoot high + hang, or shoot high + do class C, than can consistently get both balls of a two ball auto over multiple defenses. I think a triple scale, or assuming Class C crossing (which isn't that hard, even the drawbridge can be done cooperatively) is probably the more apt assumption.
If anyone was going to do it, 195 would be involved, I guarantee it.
Unread 27-09-2016, 14:11
vann2648's Avatar
vann2648 vann2648 is offline
FRC #2648 (Infinite Loop)
Team Role: Operator
vann2648 is on a distinguished road
Re: 300 Point Match
This thread causes me to wonder the highest scoring alliance possible in FRC right now. My pick would probably be 254 - 195 - 148. This combination allows for 80 point auto, an insane boulder teleop score, and a consistent triple hang. (Alternatively, replace 195 with 971 or 1678)
