Go to Post Prepare to be surprised, amazed, awed, and inspired. - Alan Anderson [more]
Unread 21-09-2016, 17:11
AkashB AkashB is offline
FRC #3182
AkashB is an unknown quantity at this point
Exclamation Joystick Issues
Hey, when testing our team's robot, the josyticks became inverted somehow. when pushing both joysticks forward (tankdrive), the robot is moving backward. I tried looking in the driver station program, but couldnt find anything about inverting the controls. Any suggestions? Thanks, Akash
Unread 21-09-2016, 18:18
Philip Arola's Avatar
Philip Arola Philip Arola is offline
You can check out any time you like
AKA: KG7VAM
FRC #1510 (Wildcats), FRC #2898 (The Flying Hedgehogs)
Philip Arola is an unknown quantity at this point
Re: Joystick Issues
1) Did they switch in the middle of driving, or just from the last time you recall driving?
2) What joysticks are you using, and are you using the same joysticks as before?
3) Did your programmers add a reverse function to the code?
4) Was the robot rewired (perhaps the motor polarity switched)?
Cunningham's Law: The best way to get the right answer on the Internet is not to ask a question, it's to post the wrong answer.
Unread 21-09-2016, 22:09
FRC #3182
Re: Joystick Issues
1. They switched from the last time it was turned on
2. Same Joysticks
3. Probably.
4. Nope, they are in the right way.
Its probably the programmers that were testing something and forgot to revert it. I'll check with them, but thanks for the help and quick reply.
Unread 27-09-2016, 08:25
Taggerun's Avatar
Taggerun Taggerun is offline
The Lone Programmer
FRC #3036 (DROBA Warriors)
Rookie Year: 2016
Taggerun is an unknown quantity at this point
Lightbulb Re: Joystick Issues
Labview or Java or C++? I know may know the issue if you use Labview!
Thanks,
Taggerun
3036
Unread 27-09-2016, 10:48
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Joystick Issues
You should also consider the possibility that the left and right side drive trains have been swapped. This could be a result of wiring , configuration of the motor controllers (if CAN), or in code.
Unread 27-09-2016, 10:51
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Joystick Issues
Or even something as simple as the order the joysticks were plugged in!
2016: Lake Superior WFFA
