Go to Post "Simple" is about staying within boundaries. - dtengineering [more]
Unread 24-09-2016, 15:09
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
pic: Piston-in-Tube Concept
Unread 24-09-2016, 15:11
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: pic: Piston-in-Tube Concept
Team 5830 did something similar for their climber last year, though not including the protection for the stroke (obviously, given the dimensions). It is nice how neatly these cylinders fit in such tubing.
"The breakfast of champions!"
Unread 25-09-2016, 01:18
Rather than using bearings, what's keeping you from using a short section of tube of the next size up, and possibly applying a thin sheet of delrin or HDPE as a bearing surface?
Some clever material selection here could eliminate the bearings entirely, while still providing the same effect.
I'd be a little leery of only using two bearing sets if straightness was critical (it often is), and would suggest 3-4 sets (2 on one side, 1-2 on the other) in such applications. Or, as noted, some clever material selection.
Unread 25-09-2016, 12:28
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
We did something like this back in 2011, but only the cylinder was in the tube, not the piston rod. Rather than using bearings we used linear slide rails on the mechanism it was actuating. Worked pretty good, and definitely saved space.
Unread 27-09-2016, 13:04
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Isn't a pneumatic cylinder on its own already a piston-in-tube device?
You could shave some weight off if you used a bracket to secure a tube to the nose of the cylinder so that only the piston rod is enclosed. You might need to rethink mounting, but the weight saved would be non-negligible. In addition, it could be argued that such a design would be more faithful to the name.
Unread 27-09-2016, 13:58
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
We did something similar with Delrin tubes and bars for our 2013 climber (underside, CAD shot). No rollers since the Delrin slides. It ended up being a good way to steamline the package for the pyramid skids. Be ready to demonstrate to the inspectors that you haven't modified the cylinders, however. Some RIs will pay close attention to any pneumatics they can't clearly see. (We showed them a spare.)
Unread 27-09-2016, 14:04
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Generally, in my experience, these kinds of things are more for saving space than weight. Square tube is also much easier to mount things to.
Unread 28-09-2016, 13:31
AKA: Alan Wells
FRC #1350 (Rambots)
Any weight that can be shaved off is more weight for future improvements. Furthermore, if you wanted to place the mount near the nose of the cylinder anyway, the method I proposed would not present any impediment.
