Personal Fabrication Tools
Hello Chief Delphi!
My name is Johnny. I am a Senior at Inspire School of Arts and Sciences, Several of my peers and I are diving into the field of personal fabrication for our Senior project. We need input from our potential market. We would like you to take a few minutes to complete our survey so we can better understand demands of the personal fabrication community. If we are successful, our product will be taken to the open market for everyone to access. https://docs.google.com/forms/d/e/1F...k0V_w/viewform Thank you for your input. It will be used to determine the best possible solutions for our project. |
Hello Chief Dephi!
Re: Personal Fabrication Tools
For the question "What size build area do you normally require?" what are the units?
EDIT- Oh. Obviously I didn't really answer as if you meant nanometers, but I did think you meant feet. Sorry about that. Last edited by Cothron Theiss : 09-27-2016 at 05:03 PM. |
We meant inches. Thank You so much for pointing that out!
This is a very cool idea, and there are already machines which do a similiar thing.
The main issue I see is that the forces are very different, you will need powerful stepper motors and strong lead screws/frame for a CNC mill/router as there is a significant loading, and these motors will end up being too slow when you need to print/engrave/cut. Also you should really add a section about what materials people want to work with, I understand that your Laser Cutter will probably only be able to cut wood/plastics. But with the CNC mill, for FRC teams( and me personally) they will want to be able to work with aluminium and that isn't going to work if you have a little 775 motor as your spindle as many compact Chinese CNC's do. Also the size of build area that you would normally see on a 3D printer( lets say 8x8) is kinda limiting on a Laser Cutter and router/mill For personal use I would much rather buy 3 seperate machines cheap from China, then purchase one little machine that does all 3 terribly. If you guys want some ideas you should look at the Sienci Mill: http://sienci.com/ Last edited by roboruler : 09-27-2016 at 09:12 PM. |
#7
You just don't have enough fields for all the portable CNC tools I currently own personally:
2 MaxNC 15 mills with CNC 4th axis, touch plates and probe 1 MaxNC 10 mill with touch plate 2 MaxNC T2 lathes 1 Seig X2 with Hoss modifications 2 LPKF Protomat 90s circuit board mill / engraver 15 3D printers, including: 2 Up! Plus printers, 1 SoliDoodle 3 and lots of Prusa 2 ShopMaster mill/drill/lathes, one configured for CNC right now, the other manual but the retrofit is still there. 1 48" portable CNC router/plasma cutter custom table (the steel supports come out with the water trays and the table converts to hold a high speed 1/4" shank router with a SuperPID - custom job by an old friend very nicely done). I personally own this stuff, fix it and acquired it all used. I have quite a few BobCAD/Mach3/FastCAD licenses floating around. I do some commercial work on them, but it's mostly side projects: enclosures, mounts, signs, letters, car parts... Eventually this will all be moved from my home and various storage locations to a makerspace somewhere. (When your house starts to look like Dean's on a smaller scale, you might want to reconsider your hobby. Many thanks to my extremely cool girlfriend with regards to my tools). Last edited by techhelpbb : 09-27-2016 at 10:47 PM. |
#8
![]() Your girlfriend IS extremely cool. Hang on to her. How well does the LPKF work? |
#9
I recently did an RF board with a network analyzer as an accessory. Basically setup the process with short connectors on one end of the PCB then: cut, test, repeat till the PCB traces had the desired RF characteristics. Mostly because I wanted to see if I could make that work and it did: I made tuned traces, inductors, and even a really tiny value capacitor which was just a test. (Capacitors like this are usually sub-picoFarad and since the PCB is unsealed and composite PCB material absorbs moisture the value changes). I have also cut thin stencils so I could screen print UV cure solder mask onto PCB. This is handy when I need to solder something where paste alone would migrate. I use my UV lamp box for curing that resin. My UV lamp box is a storage shelf with a wooden enclosure I made, a thermometer and a timer to run the bulbs. My solder oven is an old kitchen convection oven with better controls I made. My PCB cleaner is either my Chinese ultrasonic tank or the dish washer with a waste bucket to keep stuff out of the septic. (Keep in mind almost all commodity trading on Earth went through a system I made that was soldered in a toaster oven and cleaned in a dish washer. Those boards are 25 years old and still fully operational, even over-clocked by a few MHz. A little ingenuity and some testing saved me a ton of cost on an oven and cleaner.) Last edited by techhelpbb : 09-28-2016 at 09:07 AM. |
#10
Your day job sounds fascinating. |
#11
My day job is I do core engineering for an International bank I own a part of in Puerto Rico. We do BitCoin/Ethereum and other bleeding edge financial technology. Mostly writing Java/Python/Ruby code. I no longer make weapon systems or manufacture professionally. I got out of weapons because I prefer to make defensive systems and the money was offensive systems. I got out of manufacturing because I could never afford all these tools on the cost my customers were willing to pay (always in need, never sufficiently enriched). I only rebuilt my tooling capacity as a hedge against a throw-away society. All this junk we buy makes us more dependent on the few people willing to make it for the lowest bid. Experience has shown me that sort of dependence does not cause innovation to thrive. So I rebuilt my capacity to insure if crisis comes I was ready to move, plus this stuff is used so I need runway to get it working as desired. (Long timers on this forum might note that I change jobs often. I do so because I get good money and opportunity each time. My base salary has increased by $100k in 5 years, and I have had as many as a few hundred reports as manager. If I can not get compensated at market rate I may take risk and move. To put that in perspective I worked 1,500 hours of 'over time' last year.) Last edited by techhelpbb : 09-28-2016 at 10:18 AM. |
#12
I tried taking the survey, but the second question did not have a viable answer among the choices.
(I chose "none" for the answer for the first question) |
#13
#14
Hey, lol, if you can not pat yourself on the back...do not expect anyone else to do it for you then wonder why they do not. What matters is you get through the day and do what you can. Haters gonna hate.
#15
