Go to Post In other words, don't worry about the results but strive for excellence in the way you live your life and everything you do. - Paul Copioli [more]
  #46   Spotlight this post!
Unread 26-08-2016, 18:33
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Re: How are teams mounting drivetrain encoders on WCD?
Originally Posted by ollien View Post
A) What do you mean by the "weighted" wheel? Do you mean the dropped wheels?
B) What do you mean by preloading chain? How would this help? You said something about moving the robot forward and then back, but I don't understand how this would help.
I'll hop in and answer, but I'm not the most qualified in the subjects, so I welcome any correction if I say something incorrect.
Weighted wheels would be the wheels actually contacting the ground when your robot drives in the direction it's about to go. For the vast majority of 6-wheel drop centers, this will be your back wheels due to the torquing of the wheels. For 8-wheelers, it kinda depends on your specific wheel placement whether the robot is on its center sets or back sets of wheels.
As for preloading this chain, they're mostly talking about removing any slack from the side of the chain that is about to be driving the robot. This prevents much shock loading from being put on your chain runs right as you start auto or teleop. And if you consider pushing the robot to be the directional opposite of the robot driving itself, pulling the robot "pre-loads" the chains so they're ready to go when you start accelerating.
  #47   Spotlight this post!
Unread 26-08-2016, 18:35
Originally Posted by Hitchhiker 42 View Post
I'd assume this would mean stretching out the chain before actually putting it on finally, so that it stretches less during actual use.
I believe what they're really talking about is temporarily pre-tensioning, or removing the slack before each match. You could call that pre-loading, but I consider what you mentioned to be a better description for pre-loading.
  #48   Spotlight this post!
Unread 29-08-2016, 15:50
gc_coxen's Avatar
gc_coxen gc_coxen is offline
AKA: Griffin Coxen
FRC #1318 (Issaquah Robotics Society)
gc_coxen is an unknown quantity at this point
Originally Posted by Nuttyman54 View Post
Just to make sure people understand here: Adam's example is valid proof that putting an encoder on an outer wheel axle will not inherently add too much variability to produce reliable autos.
I feel that it's worth adding that this is possible because 254 properly tensions their chains, which means the backlash/slop between the outer wheels and directly driven wheels is minimal. If you're using WCP sliding versablocks, you should be able to tension your chain/belt well enough to make this a viable solution as well.
As an aside, 254 and 971 gave a great talk at Champs 2015 which is recorded on Youtube about Motion Profiling and Control which is super helpful to understand how they get such reliable auto control. Worth looking at.
TLDR; If you have a reasonable tensioning method for your chains (esp sliding bearing blocks) you should be fine putting an encoder on one of the outer wheel axles.
The plan has shifted to using 9mm belts on a direct c-c with the wcp side bearing blocks. My thought was utilizing feed forward as suggested by a teammate to minimize any slop. Is there a noticeable difference between mounting to the output shaft or rear wheel axle, specifically in regards to necessary programming to counter backlash/slop?
2016 - Stronghold (Highlight Reel)
Auburn Mountainview | Glacier Peak | Philomath | Auburn | PNW District Championship
2014 - Recycle Rush (Highlight Reel)
Auburn Mountainview | Mount Vernon | Shorewood | PNW District Championship
2014 - Aerial Assist (A/V Crew)
Glacier Peak District | Shorewood District | Auburn District | PNW District Championship | Indiana Robotics Invitational | Washington Girl's Gen
  #49   Spotlight this post!
Unread 29-08-2016, 16:41
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
Properly tensioned timing belt runs have minimal backlash and will not require any code to compensate for play.
If you're going to use direct c-c, why bother using the WCP side bearing blocks? Teams have been very successful using flanged bearings directly in 0.125" and 0.100" wall tubes. The benefits of dropping the bearing blocks are lower weight, lower cost, slightly reduced tolerance-stackup and easier/more precise machining (circular holes vs rectangular cutouts).
Also, what size pulleys and wheels do you plan to use?
  #50   Spotlight this post!
Unread 29-08-2016, 23:52
gc_coxen's Avatar
AKA: Griffin Coxen
Size constraints in the gearbox allow for a 30T pulley running 2x 9mm HTD belts. Will be running 4" colsons.
http://imgur.com/a/jkSMH <-- My thought behind using this bearing block was additional strength around the bearing to help mitigate the effect of load on the wheel axle. I vaguely remember seeing a thread on here awhile back showing a broken frame due to placing the bearing directly in the tube
  #51   Spotlight this post!
Unread 30-08-2016, 00:22
Knufire Knufire is offline
Link? If I'm thinking of the same picture, that was in 1/16" wall tube.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
  #52   Spotlight this post!
Unread 30-08-2016, 00:35
gc_coxen's Avatar
AKA: Griffin Coxen
Hm, quite a bit of searching and I came up blank. I think you're right that it was 1/16' tube
  #53   Spotlight this post!
Unread 30-08-2016, 00:50
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
https://www.chiefdelphi.com/media/photos/43555
This?
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
  #54   Spotlight this post!
Unread 30-08-2016, 00:58
gc_coxen's Avatar
AKA: Griffin Coxen
Originally Posted by frcguy View Post
That's exactly what I was looking for.
  #55   Spotlight this post!
Unread 30-08-2016, 01:01
frcguy's Avatar
Unregistered Unuser
Cool, happy I could help. I just remembered it had the words "hulk" and "thumb" in the description so that's how I found it .
  #56   Spotlight this post!
Unread 30-08-2016, 13:17
Oblarg Oblarg is offline
AKA: Eli Barnett
I've only ever seen this happen in .063''-walled tubing, which I would not advise for use in a drive chassis anyway.
"The breakfast of champions!"
  #57   Spotlight this post!
Unread 27-09-2016, 17:54
GKrotkov's Avatar
GKrotkov GKrotkov is offline
AKA: Gabriel Krotkov
FRC #1712 (Dawgma)
GKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud of
Originally Posted by Lil' Lavery View Post
I don't have any pictures unfortunately
Here we go
ID:	21078  Click image for larger version
ID:	21079  Click image for larger version
ID:	21080  Click image for larger version
ID:	21081  Click image for larger version
  #58   Spotlight this post!
Unread 27-09-2016, 18:59
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
A couple quick notes on those pictures.
The one prominanetly displayed there was actually used with a VersaBlock we had on a manipulator joint, rather than our drivetrain. We didn't intend to have that VersaBlock slide, thus why we fastened the encoder mount down to the 2x1 aluminum with the bolt you can see. One of the drivetrain encoder mounts can be seen in the background of a couple of the pictures. For the drivetrain mount, you can see the bolts that are used for the VersaBlock are also used to secure the encoder mount.
The electrical tape was a pit repair since a crack developed in the piece that holds the encoder itself. Next year we'll likely beef up that piece. Unfortunately the tape obscures the design somewhat, but the idea is that the piece that holds the encoder can slide on the main mount structure in order to find your ideal fit. If you know your shaft lengths beforehand, you could make this all one print custom fitted to work with your shaft overhangs.
  #59   Spotlight this post!
Unread 27-09-2016, 22:35
AKA: Eli Barnett
I absolutely love that versablock encoder mount idea, and will probably urge 449 to steal it
