Go to Post I will test first 'cause you cannot learn unless you break something first! - Andy Brockway [more]
Unread 28-09-2016, 20:06
Looking Forward Looking Forward is offline
Honest Analysis
Rookie Year: 1992
Looking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond repute
Looking Forward Fall 2016 Survey
If you have a spare moment, please considering filling out this short survey regarding Looking Forward. Depending on the answers to certain questions, there may be another follow up survey prior to the new competition season. Any other discussion of improvements to LF or questions about the survey can be posted in this thread, PM'd to the Looking Forward chief delphi account, or sent via e-mail (see account details for e-mail address).
Thank you!
Unread 28-09-2016, 20:23
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Looking Forward Fall 2016 Survey
problem with the survey, or my browser or something...when I answer all the parts of question 8, it complains that I didn't answer them all...a few are blank...I play whack-a-mole for a little while, watching the ones I just answered maybe or maybe not disappear, and others go blank. then I give up.
Unread 28-09-2016, 20:33
AlexanderLuke's Avatar
AlexanderLuke AlexanderLuke is offline
Do More. Less Time.
FRC #0696 (The Circuit Breakers)
AlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to behold
It was a ranking question, so rather than rating each of the nine items on a scale of 1 through 9, it is a system where you can list in what order you found each item to be important, from what was most important (rank 1) to least important (rank 9). If you completed it as if it were a rating scale, then it probably made the prior selection of the same number blank, so that there were not two things ranked the same way.
That was my experience at least. Hope what I said makes sense.
2014-Present ~ Team 696: The Circuit Breakers - Student Leader and President, Drive Coach, Mechanical Designer
Unread 28-09-2016, 20:34
Honest Analysis
Rookie Year: 1992
Q8 has been redesigned to hopefully avoid this issue
Unread 28-09-2016, 20:47
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
I was able to answer that question without issue using Chrome.
I think LF should continue to drift away from event predictions and more toward big picture concepts and trends. I remember when LF was the only one doing event predictions and recaps of every regional, but now there are a ton of events and a lot of other more regional accounts doing similar predictions. I haven't seen anyone, however, match LF on analyzing the big picture evolution of game play.
Instead of trying to preview a majority of the events (which is getting extremely hard to provide anything more than "these 4 teams are good" for some districts), I would prefer a couple of paragraphs on the major trends, a preview of the one or two most exciting events, and then an MMQB style "10 Things I Think" with random insights/thoughts/predictions/info about events or robots.
Unread 28-09-2016, 21:11
MrForbes's Avatar
AKA: Jim
Perhaps I didn't read the instructions well enough? I'll give it another try....
edit: It saved the previous page, that was nice. Still seems like too much work to answer question 8, having to rank all of the criteria, but the new layout is much easier to deal with, thanks!
Unread 28-09-2016, 21:25
WCBC's Avatar
WCBC WCBC is offline
West Coast Best Coast
WCBC has a reputation beyond reputeWCBC has a reputation beyond reputeWCBC has a reputation beyond reputeWCBC has a reputation beyond reputeWCBC has a reputation beyond reputeWCBC has a reputation beyond reputeWCBC has a reputation beyond reputeWCBC has a reputation beyond reputeWCBC has a reputation beyond reputeWCBC has a reputation beyond reputeWCBC has a reputation beyond repute
Looking Forward to hearing from you!
Unread 28-09-2016, 21:31
Honest Analysis
Rookie Year: 1992
FWIW, that question was basically reused from the 2014 survey. In 2014, each category was allowed an independent ranking. As a result, there ended up being pretty heavy clumping of responses (apparently everything is important). The hope was that a ranking system would force more spread of the responses to see what readers valued most. Sorry that the question is somewhat cumbersome.
Unread 02-10-2016, 14:42
Honest Analysis
Rookie Year: 1992
Reminder that this survey is still open.
Unread 02-10-2016, 14:45
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Oh boy...
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 02-10-2016, 15:51
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
I did the survey. I love reading about whats going on at other regionals and districts and it's one of my favorite things to read during the week.
There was one question about reading on other sites. I'm good with LF being other places to give it coverage, but I'd hate to see it be dropped from CD to be at some place like Reddit.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 02-10-2016, 19:40
itsjustjon's Avatar
itsjustjon itsjustjon is offline
#HoldStrong
AKA: Jon
FRC #3309 (Friarbots)
Team Role: Marketing
Rookie Year: 2015
itsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud of
I don't believe they'd ever actually drop CD coverage merely because more FRC people view CD than the /r/FRC subreddit. Organizations typically go where they can get the most support.
That being said, Reddit is still a great place for LF because its nested comment structure is better for discussion than CD's direct reply system.
2016: Beach Blitz Lead Queuer, Newton Quarter-finalists, Orange County Regional Winners, Los Angeles Regional Dean's List Finalist, Los Angeles Regional Chairman's Award Winner
2015: Curie Quarter-finalists, AZ West Regional Winners, Las Vegas Regional Finalists
Unread 02-10-2016, 19:41
Abdul Compton Abdul Compton is offline
Abdul Compton is an unknown quantity at this point
Pardon me, however I disagree with such an opinion. Although I personally prefer neither over the other, what makes reddit a lower alternative than CD?
Multiple Advantages:
-Cleaner UI: easier to organize and respond to certain comments
-Anonymous: allows for the "truth" and minority opinions to be heard
-Student Input: obviously more kids prefer reddit so you get input and coverage from the kids who benefit from LF
Not saying that your opinion is invalid, just wondering why you have such a strong stance against reddit?
-Abdul
Unread 02-10-2016, 20:14
FrisbeeFunTime FrisbeeFunTime is offline
Rookie Year: 2015
FrisbeeFunTime is an unknown quantity at this point
With regards to the sharing scouting info question you may want to have a "Not my decision" option for those who do not control what happens with scouting which is likely most of the individuals completing the survey. Anyway excited to see the Looking Forward name reaching out to the community to see what they want to see from it.
Unread 02-10-2016, 21:24
-Abdul
Vast, vast levels of snark. I've been to more than a few sites where the firewall blocks Reddit. There are a few places that are well moderated, but lots more are not.
