Go to Post You're not crazy. Eleven is the new seven. - Michael Corsetto [more]
Unread 29-09-2016, 12:43
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
Re: Motorizied flow control
Attached is a sketch on how to use check valves to make using a closed center 3 position valve legal under FRC rules (at least for 2016)
Unread 29-09-2016, 13:21
Levi Madden's Avatar
Levi Madden Levi Madden is offline
Student
FRC #1987
Levi Madden is an unknown quantity at this point
It is important to note that you connect the check valve to your working pressure, not your stored.
Unread 29-09-2016, 14:09
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud of
Oh very cool, thanks! With a setup like that you could create a pneumatic position control system (like http://www.bimba.com/Products-and-Ca...ntrol-System/). Add a pneumatic rod lock (http://www.bimba.com/Products-and-Ca...Line-Rod-Lock/) and you could move and hold actuators with very few mechanics.
The downside is the limited compressor size means you wouldn't be able to move a cylinder bigger than ~1" more than a few cycles a match.
