Go to Post "Why even bother building a robot if we're not gonna win?". The answer? To learn and grow. - MrBydlon [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.50 average. Display Modes
Unread 01-10-2016, 10:04
rajumhvsn rajumhvsn is offline
Electrical Engineer
FTC #11356 (Larson Robosonics)
Rookie Year: 2016
rajumhvsn is an unknown quantity at this point
Android Studio Error: CreateProcess Error = 216
We are a rookie team and I am helping a new student in my team to setup Android studio and I am getting the following error:
"Error: CreateProcess Error = 216. This version of 1% is not compatible with the operating system.Check your computer system's information if you have a 32 bit or 64 bit version."
Below is the system details:
These are the versions of jdk , Android studio and ftp-app.
• jdk-8u101-windows-i586.exe
• android-studio-bundle-145.3276617-windows.exe
• ftc_app-master.zip
My system configuration
Windows 7 Enterprise, 32 Bit operating system
Error Message
Error:CreateProcess error=216, This version of %1 is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need a x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publisher
Has anybody come across this issue? Need some help. Thanks
Unread 02-10-2016, 00:33
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Android Studio Error: CreateProcess Error = 216
You may get a better response from this forum:
http://ftcforum.usfirst.org/forumdis...Android-Studio
Unread 02-10-2016, 10:58
Electrical Engineer
Rookie Year: 2016
I don't have access to post in that forum yet. Hence posted the question in this forum.
Unread 02-10-2016, 13:48
mikets's Avatar
Software Engineer
Are you sure you have a 32-bit Win7? It is kind of rare with newer computers nowadays. According to your info, the JDK you downloaded was 32-bit so that's fine. But the Android Studio does not have different packages for 32-bit and 64-bit so I assume it can do both. You need to determine which program put out that error message? The %1 in the message seems to be the program name but for some reason it did not show up. Another possibility is some sort of DLL confusion meaning there was a different version of a similar program installed that confused Android Studio. For example, have you installed a different version of the JDK before? If you accidentally installed a 64-bit JDK before, it will stick around even though you later installed a 32-bit JDK. Take a look at the folder c:\Program Files\java. What folders do you see there?
