Go to Post A solution will present itself, all you have to do is be ready to take advantage of it when it does. - James1902 [more]
Unread 30-09-2016, 09:59
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
paper: The HERO for FRC
Thread created automatically to discuss a document in CD-Media.
The HERO for FRC by marshall
Unread 30-09-2016, 10:00
marshall's Avatar
Re: paper: The HERO for FRC
We're happy to answer questions about our experiences using the HERO from CTRE! It's been a great project to work on for us and we're thrilled to have had CTRE sponsor our work on this.
If you're looking for an alternative control system for a robot then we can highly recommend the HERO. It's a great platform.
Unread 30-09-2016, 10:30
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud of
Thanks! This is timely, as we're deciding how to keep our demo robots running without forking out $500 for another roborio.
Unread 30-09-2016, 10:31
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
So what advantages does the HERO offer over the cRIO? Is this just a cheaper alternative for non-competition bots or is this a possible replacement for the cRIO?
Also, this is great work from what I can tell. (Though my extent of electrical and programming knowledge is that it's basically all sorcery, so who knows?)
Unread 30-09-2016, 10:41
marshall's Avatar
Thanks! We have been trying to get out there for teams exactly for that reason. It's a great choice for that... at least it was for us.
  • It's cheaper.
  • It's supported now (not that the cRIO isn't but it wasn't for us... the 2CAN LabVIEW drivers/libraries for the cRIO are kinda busted now).
  • It's cheaper.
  • It doesn't require a driver station to run.
  • It's a lot simpler to wire up.
  • It allows you to use Talon SRXs with it via CAN.
  • It's cheaper.
Yeah, there is a lot to like.
Unread 30-09-2016, 10:47
Originally Posted by marshall View Post
  • It's cheaper.
  • It's cheaper.
  • It's cheaper.
I'm noticing a theme....
In all seriousness, that is good to know. My team has only disassembled our 2014 robot and we built a demo bot for kids out of the chassis, but we've been stripping the control systems off of all but the demo bot and this year's, so we could use some cheap control systems.
We would have no need for CAN capabilities, so could the price point be dropped even further by using Sparks?
Unread 30-09-2016, 10:57
marshall's Avatar
The HERO does provide PWM outputs but it's not something we've tested. If you go that route though, you'll need to breakout the 10pin .05" headers to PWM connections.
Something like this should work for breaking out the PWM connectors: http://core-electronics.com.au/servo...ompatible.html
Unread 30-09-2016, 11:02
Thank you for that; I'll let them know that option exists.
Unread 03-10-2016, 08:38
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Have a wiring diagram to share, and a priced BOM?
I have two robots that I would also like to keep running, I have one already working with the ardunio and 221 hardware.
Can you talk about what the srx breakout was used for?
The sooner we get behind schedule, the more time we have to catch up.
Unread 03-10-2016, 09:25
marshall's Avatar
Wiring is dead simple, it's 12V and CAN. I don't have a diagram but maybe I can bribe a student into making one. It really isn't hard though.
The breakouts were used to attach the encoders on the drivetrain to the Talon SRXs. We plan on testing out motion magic and motion profiling on this robot within the next few months so we'll need the encoders. We also needed them to attach to the limit switches to prevent our mechanism from breaking.
BOM:
1x HERO - $60
6x Talon SRX - $90x6 = $540
4x Encoder Breakouts - $10x4 = $40
Total Cost = $640
That might seem like a lot if you are buying all of the parts new but I suspect most teams won't be and instead might be looking to keep their stronghold robot online and working which might be using CAN today. The bulk of the cost is from the Talon SRXs and if you don't need to purchase those or plan on purchasing new ones then it's not that bad.
