Go to Post Much of what you do in the "real world" has no rules. You have to look yourself in the mirror and make them up as you live; knowing that what you do WILL come back to haunt you sooner or later. - dhitchco [more]
View Poll Results: Do you know what this is???
Yes 67 73.63%
No 5 5.49%
What is that?????? 19 20.88%
Voters: 91. You may not vote on this poll
Unread 03-10-2016, 09:50
Taggerun's Avatar
Taggerun Taggerun is offline
The Lone Programmer
FRC #3036 (DROBA Warriors)
Rookie Year: 2016
Taggerun is an unknown quantity at this point
Question 2009 DS Help!!!
I have no clue what this is. Could someone tell me what this and if it can be used!!
Thanks,
Taggerun
My favorite robot?
The Aluminium Annihilator
"Oh yeah, it's British!!!!"
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
Unread 03-10-2016, 09:51
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is online now
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: What is this????
It's an old drivers station from 2009ish. It can't be used.
Unread 03-10-2016, 09:52
Taggerun's Avatar
The Lone Programmer
Rookie Year: 2016
Are you sure???
My favorite robot?
Unread 03-10-2016, 10:14
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It's the 2009 driver station. Not "ish", it is the 2009 driver station.
You might be able to find a use for it.
Unread 03-10-2016, 10:16
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
If it's like most of the other 2009 driver station's I had experience with, it's probably dead from static shock by now!
2016: Lake Superior WFFA
Unread 03-10-2016, 10:17
Taggerun's Avatar
The Lone Programmer
Rookie Year: 2016
Question Re: What is this????
But how?? Is there any software I can find for it??
Thanks,
Taggerun
My favorite robot?
Unread 03-10-2016, 10:18
MrForbes's Avatar
AKA: Jim
Now that you know what it is, you can search for software.
I expect it would be challenging to use it.
Unread 03-10-2016, 10:20
Billfred's Avatar
Billfred Billfred is offline
You're correct in paragraph 1, but given how awful it was for the purpose (ethernet jacks not built for enough connect-disconnect cycles, static discharge issues requiring everyone to crack a case open, very limited controller options) I would say Ty's closer to the mark on its actual utility...
That said, it might be a tempting project for a hardware hacker.
Unread 03-10-2016, 10:30
Taggerun's Avatar
The Lone Programmer
Rookie Year: 2016
What do you mean by challenging??
My favorite robot?
Unread 03-10-2016, 10:40
MrForbes's Avatar
AKA: Jim
What do you intend to use it for? If you want to use it to work with the complete 2009 robot control system, you'd need to find the appropriate software. That was the first year of the cRio control system, things were kind of flaky. From the little bit I know about configuring the control system, you probably need an old computer that still has the appropriate programming environment software loaded on it, you probably can't use a newer version of LabView, for example.
If you want to play hacker and use it for something else, you might see what controller it has inside, and figure out how to change the firmware to your own code, and make it do what you want.
There are probably other uses that I have not imagined here, if you give us some ideas of what you have in mind for it, we can help you figure out what the challenges might be.
Unread 03-10-2016, 11:18
bobbysq bobbysq is online now
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
It seems like if you have this, you probably have a cRIO already. You can program the cRIO with Eclipse using the Thunder cRIO tools or you can use LabVIEW if you image it properly. Then, you can take the driver station, set it to the 2014 protocol, and run it as normal.
Unread 03-10-2016, 12:27
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Mmmm scrap used parts.
Dismantle, find data sheets and have fun.
Unread 03-10-2016, 13:53
Taggerun's Avatar
The Lone Programmer
Rookie Year: 2016
Good as dead??? Wrong!! Now what after this screen??
Thanks,
Taggerun
My favorite robot?
Unread 03-10-2016, 13:59
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
You might be able to use the display screen for something. Other than that, it goes on the "Wall of Fame/Shame".
It was the first DS that allowed use of USB joysticks and devices.
Unread 03-10-2016, 14:26
Billfred's Avatar
...natively. The USB Chicklet allowed supported USB joysticks and devices to connect to the old IFI OI's gameport connectors.
