Go to Post Being good people is as important as being the winners of some robotics competition! - ExTexan [more]
Unread 21-09-2016, 18:39
bcampbell's Avatar
bcampbell bcampbell is offline
bcampbell will become famous soon enoughbcampbell will become famous soon enough
Re: Robot Cart
We have a custom cart we built ourselves. Here is a picture of our cart. If you look closely there are 4 orange blocks that the robot sits on. Those blocks are adjustable and can move along the entire top rail of the cart via a standard bolt pattern. This allows us to change the cart to carry the current years robot without any modifications. 8 bolts later you can change it to fit any robot. We have roughtop on top of the blocks to get a good grip on our drive rails and to keep the robot in position. We have casters on the bottom of the cart that are similar to a grocery cart with 2 stationary and two rotating wheels that allow for easy movement. The back push bar lifts up to allow full access around the robot. When we are working on the robot in the pit the bar is removed so it is not in the way. The bottom shelf allows for storage of the control board, batteries and anything else we need.
Unread 21-09-2016, 21:33
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Re: Robot Cart
Anyone ever used one of these?
We are looking at buying something like that and modify to add tools/battery storage.
Love the jack capability and flat surface to allow mounting specific frame based on robot design....
Unread 21-09-2016, 22:34
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
Re: Robot Cart
Think you forgot the link/picture.
461 Westside Boiler Invasion
45 Technokats
Unread 03-10-2016, 14:16
Coach Seb's Avatar
Rookie Year: 2015
Re: Robot Cart
sure did....
http://www.northerntool.com/shop/too...1992_200631992
Unread 03-10-2016, 17:32
346CADmen's Avatar
346CADmen 346CADmen is offline
FRC #0346
346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold
Re: Robot Cart
I like what you like about this cart. What I don't care for are the width (tight thru a door) and weight.
Also, I would remove the handle and make one that pivots or is removable.
Unread 03-10-2016, 19:42
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Robot Cart
It's under 18" wide, not sure you are going to get anything narrower than that.
We considered having a lift on our cart and we couldn't justify the cost, weight, or space for often we saw it being useful.
Unread 03-10-2016, 20:21
jakey99's Avatar
jakey99 jakey99 is offline
FRC #2656 (Quasics)
Rookie Year: 2016
jakey99 is an unknown quantity at this point
Re: Robot Cart
We have two carts. 1 is for our actual competition. It is large and has plenty of storage for loading and unloading from competition, with the robot and bumpers. We also have another one for scrimmages and outreach events. It is just large enough for the robot to sit on it and not touch the ground.
Unread 04-10-2016, 07:27
346CADmen's Avatar
FRC #0346
Re: Robot Cart
You correct I mistook what I read on width. Weight is still an issue. We had one like this so I recall those things. Weight here comes from cylinder,able to lift 500 lbs.
However this may be needed this year as we may be using steam power.
Unread 04-10-2016, 07:55
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Robot Cart
The needs for the robot cart change every year (not as much as the robot, but they change). The thing we purchased as a robot cart in our rookie year (ComboCart) never seems to be quite the right thing. On the other hand, a simple garden cart similar to this* has been the base of our cart the last four years; we usually spend more time figuring out what the cart needs than in the [re]build. There are so many carts and such available locally between home centers, garden stores, and such that can be tweaked into what we need that it is unlikely we would order something that needs to be shipped.
* - hey, they're available in green now!
Unread 15-10-2016, 17:42
colbyk1 colbyk1 is offline
FRC #0353
colbyk1 is an unknown quantity at this point
Re: Robot Cart
My team uses a old gurney from an ambulance its great because we adjust the wood blocks that sit on top of the gurney each year to fit the robot.... I dont really have great photos of it but.... http://pobots.wixsite.com/team353/ph...aItem-iikighoe
