Re: FMS-lite / cheezy-arena - having trouble getting driver station to show up
When using a static IP on the DS, always use 10.TE.AM.5 with a subnet mask of 255.0.0.0. The static address for the RoboRio should be 10.TE.AM.2 with a subnet mask of 255.255.255.0. The FMS (FMS Lite/Cheesy Arena) should also always be at 10.0.100.5. Here is the slightly tricky part. If you intend to use the security settings in CA, you really should be using the hardware they have called out. That said, I believe it might still be possible to use CA without it, but don't quote me on that. To flash the robot radio to use a specific SSID and WPA, you can use the Radio imaging tool from the KOP, but make sure to use it in "FMS Lite" mode. I hope this helps a bit. BTW, I wish you had asked for help at Chezy Champs, I was FTAA there. Can you provide so more detail as to what exactly your Auto routine does and how you had your components configured? (IP's etc.) |
