Go to Post Yeah.... I'll pay money just for a picture of Andy [Grady] getting jiggy! (then recommend it for the Caption contest!) ;) - Rich Wong [more]
  #106   Spotlight this post!
Unread 01-10-2016, 00:54
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: What is the most ghetto thing you've seen on a robot?
It may not be the most ghetto thing I ever saw, but we definitely made a data point last night. After three weeks of completely rebuilding the air cannon (which we traditionally do every 18 months or so, but this one made it simpler rather than more complex, yeah!), something in the arduino code just did not work. This code was finally available and tested to a fail at about 1700 (5pm), and the game started at 1900 (7pm). I took to the streets to buy starter switches, horn switches, and wire. After visiting three different auto parts shops, we got down to a wonderful fast build - everyone was out of the comfort zone, myself included. While we did not make the 1900 start of game, the robot rolled out before halftime with a 12 foot (3.6m) tether consisting of 8 12 ga wires (4 red, 2 green, 2 blue) to switch the four motors on starter switches and a four-conductor set of trailer wires to switch the two solenoid valve launchers, all in a wire handler bundle, coming up into a too-small radio shack project box (the only one in the shop, can you believe it?) with the switches. We could only drive forward, with slight turns by pushing only on one side, but we helped keep the home crowd entertained as our football team lost 21-3 to Covington. Official tryouts start a week after next, but a handful of our new recruits made the cut in my mind last night.
  #107   Spotlight this post!
Unread 01-10-2016, 09:34
berkleyfanatic's Avatar
berkleyfanatic berkleyfanatic is offline
FRC #0247 (Da Bears)
berkleyfanatic is an unknown quantity at this point
In 2015 our winch for lowering and raising our arms broke either before or during semi finals so we had to use duct tape to fix it
  #108   Spotlight this post!
Unread 01-10-2016, 09:42
Billfred's Avatar
Billfred Billfred is offline
I'm sure I've participated in worse and am forgetting, but:
Palmetto 2016. Most of the teething problems on Sandstorm III's drivetrain were sorted out early on, but right as alliance selection starts a message goes out on the Garnet Squadron group chat: Decline any invitation, drivetrain lost a bearing deep inside. I was just across the way as the defense coordinator, so I bolted over to the pit. Sure enough, one of the center inside bearings had popped free into the box tubing. We had the spare, and I had a flash of brilliance. Take the spare bearing, line it up with the hex shaft and hole, whack it with a hammer and wood block, and maybe it'd be enough to buy us some time, right? I took the whack, figuring we'd either be functional or just as hosed...and by some miracle, everything nestled into place and we would be ready for action.
Of course, we didn't get picked anyway...
  #109   Spotlight this post!
Unread 01-10-2016, 13:44
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
I think our second robot counts
We designed both robots to be modular, so the shooter, intake, and cheval wedges can be swapped as part of withholding allowance. By postseason (we were registered at Beantown Blitz) we really wanted our second robot to be able to compete as well and this was the result:
https://www.flickr.com/photos/ligerb...7667311431234/
Here you can see:
- stapled bumpers
- ziptie- and duct tape-based intake
- wooden shooter (needless to say it didn't last very long)
- PVC tube boulder blocker complete with transparent packing tape.
Thus the second robot was aptly renamed "Jankosaurus Rex"
Nevertheless our team had a lot of fun putting it together in just a few team meetings before Blitz
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
  #110   Spotlight this post!
Unread 02-10-2016, 01:59
Jonah Sachs's Avatar
Jonah Sachs Jonah Sachs is offline
FRC #0694
Jonah Sachs is an unknown quantity at this point
This:
  #111   Spotlight this post!
Unread 03-10-2016, 10:50
Thayer McCollum's Avatar
Thayer McCollum Thayer McCollum is offline
[Insert Name Here]
FRC #0159 (Alpine Robotics)
Rookie Year: 2015
Thayer McCollum will become famous soon enoughThayer McCollum will become famous soon enough
What is that?!?!
I'm an advocate of getting something to work by any means necessary and so I'm usually able to tell what each jury-rigged sketchy piece does, but with that I don't even know... Might I ask what happened that required that... contraption?
  #112   Spotlight this post!
Unread 03-10-2016, 14:28
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Originally Posted by Thayer McCollum View Post
What is that?!?!
That is one of the most unlikely wheels on Einstein: https://www.chiefdelphi.com/forums/s...d.php?t=150021
  #113   Spotlight this post!
Unread 03-10-2016, 17:33
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
For Recycle Rush, one of our students had the idea of using a deformable structure on our 3310-style canburglar to absorb impact energy and reduce bounce. His implementation? He taped an empty soda can to each carbon fiber rod.
  #114   Spotlight this post!
Unread 03-10-2016, 18:04
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Team As Sketchy As Possible hasn't shown up in here yet? We need to step up our CD game.
2013: For the most consistent points in every match, Optimus Climb started on the corner of a tower. It then fell over and spent the whole match climbing up it. This was also entirely in teleop.
2015: A milk jug was used to create spacers on our pulley. We also had a slide drive that only worked on our concrete shop floor and never carpet.
2016: At the Iowa scrimmage, we found that our intake was good for firing boulders straight up. Solution: Sherman 1.2: Bagbot. (we later decided to just make a bootleg of another team's intake in the 4 days between CIR and Iowa)
  #115   Spotlight this post!
Unread 03-10-2016, 19:23
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
If you think that's bad, you haven't seen our 2013 robot. It was similar to yours, but instead of pulling itself up, it spent the whole match slowly flipping itself end over end up the tower, trying not to rip the tower apart in the process. We usually try to forget that year ever happened.
  #116   Spotlight this post!
Unread 03-10-2016, 20:13
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of light
At least you got up the pyramid
Besides that, the awful mess of velcro, tape, and zip ties that struggles to keep our 2016 climber arm just for it to break.
And in 2014...this
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
  #117   Spotlight this post!
Unread 03-10-2016, 22:33
logank013's Avatar
logank013 logank013 is offline
System.out.println("Ready!");
AKA: Logan Kreisher
FRC #0234 (Cyber Blue)
Team Role: Scout
Rookie Year: 2015
logank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant future
In NC this year, our alliance in the playoffs had a very interesting time.
  • Our tread fell off both matches
  • Team SPORK 3196 had some issues with their high goal shooter breaking. Before the QF matches, they determined it wasn't fixable and went with a low goal shooting mechanism. In order for their auto to work, a switch had to be pressed down so they just duck taped it so the auto would work.
  • Our 3rd partner, 3680, got flipped in a match
Feel free to watch some of these matches here.
P.S. Teams in Indiana are very nice and easy to work with. But 3196 and 3680 were definitely some of the nicest people I worked worth over the last 2 years. I hope to come back next year to NC next year (and not decline like in 2016 )
Cyber Blue Season 2015
IN Indy District Chairman's Award Winner | IN Kokomo District Event Winner (With 135 and 3865)
IN Purdue District Event Winner (With 1024 and 2197) | IN District Championship Winner (With 1024 and 292)
WORLDS:
Archimedes Rank 3 After Quals. | Alliance #3 Captain
Archimedes Division Semi-Finalist (With 503,188, and 836)
Scouting is life. Excel is friend, not foe.
  #118   Spotlight this post!
Unread 03-10-2016, 23:42
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
On 399's 2013 robot we sheared a 1/4-20 bolt that drove our disc feeder kicker mechanism at a robot demo, so we used velcro to hold zipties to hold a screw driver in its place.
5012's offseason rebuild 2014 - in our first match at Chezy Champs, a collision with a partner shattered our MDF intake jaws. We spent the entire weekend rebuilding the jaw with whatever parts we could scrape together with materials from 399, 1678, 8, and 5136. We arrived in San Jose with this, and left with this monstrosity constructed from 399's spare catapult cradle, fiberglass rod, surgical tubing, and string. For our next offseason events, we rebuilt it out of 1/4" aluminum and lexan.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
  #119   Spotlight this post!
Unread 04-10-2016, 00:11
Jonny_Jee's Avatar
Jonny_Jee Jonny_Jee is offline
FRC #2085 (Robodogs)
Jonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to behold
L-bot!
https://www.youtube.com/watch?v=c4nsFmmZPmo
The most magnificent robot I've had the pleasure of working on BY FAR. The scoring mechanism is a cardboard tube attached to a piston. With a sweet 2 wheel drive and 7 caster wheels, it glides effortlessly across the arena! And how could anyone forget the 60lb steel plates zip tied to a piston on the side of the robot!
  #120   Spotlight this post!
Unread 04-10-2016, 00:29
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Originally Posted by Jonny_Jee View Post
L-bot!
Oh boy...
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
