Go to Post You know you're addicted to FIRST when...You relabled the speedometer in your parents car so that 0 is 127 - Sharkbyte [more]
Unread 03-10-2016, 15:31
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
[FTC]: All Motors - Legal for 2016-2017 (Links/Pricing/Specs)
This is the list of motors, with pricing, links, and specs that I could find. These are all of the motors allowed for this year's season. An interesting line up.
Game Manual Part 1 <RE09> DC Motors
A maximum of eight (8) DC motors are allowed. The only allowed motors are as follows:
a. Core Motor Controller and Legacy TETRIX DC Motor Controller based systems must use the following
12 VDC motors in any combination.
i. TETRIX: W39530
ii. AndyMark: AM-2964, AM-2964a, AM-3102, AM-3103, AM-3104
iii. MATRIX: 50-0012, 50-0013, 50-0014, 50-0073
iv. REV Robotics: REV-41-1300, REV-41-1301
b. Legacy MATRIX DC Motor/Servo Controller based systems powered by a 12 VDC Battery must use the
following 12 VDC motors in any combination.
i. TETRIX: W39530
c. Legacy MATRIX DC Motor/Servo Controller based systems powered by a 9.6 VDC Battery must only
use MATRIX 9.6 VDC motors (14-0001, 14-0009) in any combination. No other DC motors are allowed
for use with the Legacy MATRIX DC Motor/Servo Controller.
d. No other DC motors are allowed.
Andymark:
Encoder Cables:
am-2992 http://www.andymark.com/product-p/am-2992.htm
am-2965 http://www.andymark.com/product-p/am-2965.htm
NeveRest 20 (am-3102) ($28.00) (Encoder Included) (ENCODER CABLE NOT INCLUDED)
http://www.andymark.com/NeveRest-20-...-p/am-3102.htm
Physical Specs:
Overall Length: 5.18"
Maximum Diameter: 37mm (1.46 in)
Output Shaft size: 6mm (0.24 in) with 0.5mm deep flat
Weight: 0.762 Pounds
Mounting Holes: M3 tapped holes, qty. 6, on a 31mm bolt circle
Electrical Connection Geometry: 6-pin connector for motor power and encoder contact
Gear Material: Steel
Body Material: Steel with plastic encoder housing
Lubrication: Included with gearbox
Theoretical Performance Specs:
Gearbox Reduction: 20:1
Voltage: 12 volt DC
No Load Free Speed, at gearbox output shaft: 315 RPM
Gearbox Output Power: 14W
Stall Torque: 197 oz-in
Stall Current: 11.5A
Output pulse per revolution of Output Shaft (ppr): 560 Pulses
Performance Specs, mounted to AndyMark dyno: Coming Soon
Max Speed (under load of dyno):
No Load Current (under load of dyno):
Stall Current:
Stall Torque:
Max Output Power:
Time to Failure at Stall:
Motor Case Temperature at Failure:
NeveRest 40 (am-2964) Released last year ($28.00) (Encoder included) (ENCODER CABLE NOT INCLUDED)
http://www.andymark.com/NeveRest-40-...p/am-2964a.htm
Physical Specs:
Overall Length: 133.5mm (5.26 in)
Weight: 0.75 pound
Performance Specs:
Gearbox Reduction: 40:1
Voltage: 12 volt DC
No Load Free Speed, at gearbox output shaft: 160 rpm
No Load Free Speed, motor only: 6,600 rpm
Stall Torque: 350 oz-in
Stall Current: 11.5 amps
Force Needed to Break Gearbox: 1478 oz-in
Minimum torque needed to back drive: 12.8 oz-in
Output pulse per revolution of Output Shaft (ppr): 1120 (280 rises of Channel A)
Output pulse per revolution of encoder shaft (ppr): 28 (7 rises of Channel A)
Max Speed (under load of dyno): 129 rpm
No Load Current (under load of dyno): 0.4 amps
Stall Torque: 396 oz-in
Max Output Power: 15 Watts
Time to Failure at Stall: 2 minutes, 54 seconds
Motor Case Temperature at Failure: 190 degrees F
NeveRest 60 (am-3103) ($28.00) (Encoder included) (ENCODER CABLE NOT INCLUDED)
http://www.andymark.com/NeveRest-60-...-p/am-3103.htm
Physical Specs:
Weight: 0.776 pounds
Gearbox Reduction: 60:1
Voltage: 12 volt DC
No Load Free Speed, at gearbox output shaft: 105 RPM
Stall Torque: 593 oz-in
Output pulse per revolution of Output Shaft (ppr): 1680 Pulses
Stall Current:
Stall Torque:
Max Output Power:
NeveRest Motor (am-3104) ($18.00) (Encoder Included) (ENCODER CABLE NOT INCLUDED)
http://www.andymark.com/Motor-p/am-3104.htm
Physical Specs:
•Overall Length: 75mm (2.95 in)
•Maximum Diameter: 38mm (1.49 in)
•Weight: 0.550 Pounds
•Mounting Holes: 3x M2-0.4 x 22mm deep
•Electrical Connection Geometry: 6-pin connector for motor power and encoder contact
•Gear Material: Steel
•Body Material: Steel with plastic encoder housing
•Voltage: 12 volt DC
•No Load Free Speed: 6600 RPM
•Power: 14W
•Stall Torque: 8.75 oz-in
•Stall Current: 11.5 A
•Output pulse per revolution of Output Shaft (ppr): 28
NeveRest 3.7 Gearmotor (3.7:1) (am-3461) ($28.00) (Encoder Included) (ENCODER CABLE NOT INCLUDED)
http://www.andymark.com/NeveRest-3-7...-p/am-3461.htm
Physical Specs:
Overall Length: 5.0"
Maximum Diameter: 36mm
Output Shaft size: 6mm D
Weight: ~0.87 Pounds
Mounting Holes:4 x M3x0.5 on 28MM Bolt Circle
Electrical Connection Geometry: 4-pin connector for encoder, pre-installed 18 AWG wires with Anderson PP15 Connectors
Lubrication: Pre-Lubricated
Shaft Hardness: 45-50 Rockwell C (https://en.wikipedia.org/wiki/Rockwell_scale)
Wire Gauge: 18 AWG
Gearbox Reduction: 3.7:1
Voltage: 12V DC
No Load Free Speed, at gearbox output shaft: 1784 RPM
Stall Torque: 32.3 oz-in
Output counts per revolution of Output Shaft (cpr): 103
RevRobotics:
HEX MOTOR (REV-41-1300)
Delayed Release, Unavailable.
HD HEX MOTOR (REV-41-1301) (30.00) (Encoder Included) (ENCODER CABLE NOT INCLUDED)
http://www.revrobotics.com/rev-41-1301/
Physical Specs:
Weight: 350g
Length (excluding wires & output shaft): 97.5mm
Output Shaft: 5mm hex
Output Shaft Length: 25mm
Mounting Holes: 6 - M3 tapped - 31mm bolt circle
Voltage: 12V DC
Free Speed: 150 rpm
No-Load Current: 400mA
Max Output Power: 15W
Tetrix:
Tetrix MAX DC Gear Motor (Product ID W39530) $24.95, 4-PACK $135 (20% discount at check out) (NO ENCODER)
Single: http://www.tetrixrobotics.com/extra_..._DC_Gear_Motor
4-pack, Plus extras: http://www.tetrixrobotics.com/extra_..._DC_Motor_Pack
Normal Operation Conditions
- Rated Voltage: 6-13.8 V
- Ambient Temp. -10-+60 C
- Rotate direction: CW
Test condidtions
- Voltage DC 12V
- Ambient Temp 28 C
- Ambient Humidity 22%RH
* The tested sample is set level
Electrical features (After 30 seconds electrify)
- No-load Speed 150+- 10%rpm
- No-load current: 0.34A (0.66A max)
- Load toqure: 3.9kg.cm
- Load current 0.91A (1.37A max)
- Load Speed: 137.5+- 10%rpm
- Stall torque: /
- Stal current: /
Mecanical characteristics
- Axial play of shaft <= 0.5mm
Motor features
- No-load Current: 0.19A
- No-load speed: 1100+_ 10%rpm
Time to Failure at Stall: 6 seconds (<-- Testing other teams and we have done)
PDF of above: https://c10645061.ssl.cf2.rackcdn.co...otor739530.pdf
Matrix:
Motor (50-0012)
Unavailable for purchase.
12v 4mm Motor Kit with Powerpoles ($43.95) (50-0013) (Includes mounting hardware) (Encoder Included)
http://modernroboticsinc.com/12v-motor-kit
Physical Specs:
No Load Output Speed 140-190 rpm
Gear Ratio 52.8:1
Stall Torque 33.3 kg-cm
Continuous Torque 30 kg-cm
Encoder Resolution 1478.4 ticks per
output shaft revolution
Shaft Diameter 4mm
Shaft Length 28mm
Motor (50-0014)
Motor (50-0073)
Vex:
(Attached to Servo Contoroler through a "(Vex) Motor Control 29")
http://www.vexrobotics.com/vexedr/pr.../276-2193.html
VEX EDR 393: $14.99 (NO ENCODER)
http://www.vexrobotics.com/vexedr/pr...on/motors.html
Physical Specs:
Free Speed:100 rpm (As Shipped)/160 rpm (High Speed Option)
Stall Torque:1.67 N-m (14.76 in-lbs) (As Shipped)/1.04 N-m (9.2 in-lbs) (High Speed Option)
Stall Current:4.8A
Free Current:0.37A
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 03-10-2016, 17:36
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
Re: [FTC]: All Motors - Legal for 2016-2017 (Links/Pricing/Specs)
Just hot off the press, in other words just received email about new motor
NeverRest 3.7
Availability:
These new NeveRest 3.7 Gearmotors are currently on order and will be available early November.
Product Overview:
The NeveRest 3.7 is a planetary gearmotor with an attached encoder. The output shaft geometry is similar to what FTC teams are familiar with. This motor and gearbox combination is perfect for high-speed, low torque mechanisms.
FTC Legality: This product is a combination of a new planetary gearbox, and our existing NeveRest Motor Only (am-3104). As per the FIRST Tech Challenge Game Manual Part 1 for 2016-2017, this motor is legal based on the part number am-3104 being listed under RE09, and the gearbox following RM02.
Physical Specs:
Wire Gauge: 18 AWG
Voltage: 12V DC
2017 FTC 11722 (Coach)
2016 FTC 10544 (Coach) Canadian Championship Finalist, Rockwell Collins Innovate Award.
2014 FRC 5064 (Mentor)
Unread 04-10-2016, 12:43
RaMoore's Avatar
RaMoore RaMoore is offline
AKA: Rachel Moore
FRC #3005 (RoboChargers)
RaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud of
Just a quick correction, the encoder cable is actually included with the REV Robotics HD Hex Motor.
Physical Specs:
Weight: 350g
Voltage: 12V DC
Free Speed: 150 rpm
Rachel Moore
REV Robotics | www.revrobotics.com
Unread 04-10-2016, 15:34
Thank you Rachel. Sorry about that, was a quick copy and past from above, and forgot to change it... Of course CD wont let me edit the post though.....
www.valleyx2844.com
Unread 04-10-2016, 15:56
Enginerd
FTC #11722
Strange. It lets me edit my post.
Unread 04-10-2016, 16:32
Maybe for the first 24 hours from the original post.... cause I can edit my latest post.
www.valleyx2844.com
