Go to Post We always have a party on Friday. It's called scouting. - Meredith Novak [more]
Unread 04-10-2016, 13:43
bretcobrageek's Avatar
bretcobrageek bretcobrageek is offline
FRC #4488
bretcobrageek is an unknown quantity at this point
NAVX vs. Spartan board
We've used the NAVX for the last 2 seasons with pretty good success. But we did have issues during autonomous after bouncing over defenses with things getting off a bit. The camera helped out, but 2-ball seemed like an impossibility.
We've seen some of the top teams using the Spartan board which has a different sensor setup but seemed to perform quite well. It also has locking connectors for the PWM's which is cool (other than having to buy new connectors), but we really haven't had that much problem with PWM wires coming loose.
Has anyone used both of these? Have any good experienced comparisons for us? Thanks!
Unread 04-10-2016, 13:54
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
Re: NAVX vs. Spartan board
I can't speak to the NAVX or offer comparisons, but we had a great experience this season with the Spartan Board. If you PM AWol (Adam) on my team, he can give you better details than I can.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 04-10-2016, 14:01
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I'm a bit biased, but we used the first rev of the spartan board and liked it so much we asked the folks @ 971 if we could produce it. The intial spartan board had us hooked because we only drifted 1-2 degrees over an entire match using our swerve. We found that fairly impressive compared to what we had been using previously. Again I'm pretty biased but I figured I'd share our team's experience.
R.C.
MadTown Robotics Team 1323
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
I can comment a bit but I will add that I haven't used the Spartan Board. I have however used the gyro that the Spartan Board uses (http://www.analog.com/media/en/techn.../ADXRS453.pdf). It's not any more or less accurate than the NavX IMU.
I'll also say that our team has used the NavX for a couple of seasons now and we're madly in love with it. So much so that we wrote the LabVIEW libraries for it. We're also doing some neat things with the NavX micro now too.
They are both great products and each have their uses (the locking PWM pins are very compelling). That being said, using an IMU or Gyro really comes down to your code for the most part.
If you're having issues bouncing over defenses then it's possible you were trying to poll data too quickly or not filtering out anomolous data or didn't do enough testing. It's likely not the hardware.
Unread 04-10-2016, 14:59
dougwilliams's Avatar
dougwilliams dougwilliams is offline
Engineer - Controls, Electronics
FRC #2053 (TigerTronics)
dougwilliams is on a distinguished road
We have used the navX and navX-MXP for the last few years. I'm not sure what failure or anomaly would cause what you described; anecdotally, I'm sure many teams bounced over many defenses many times without issue.
Scott from Kauai has been incredibly responsive and helpful for any issues; I'd run this by him if you haven't already.
That said, I've never heard of the Spartan board until this thread. I see WCP has a product page, but there's no technical details listed at all. Where can you find more information? (I'd also be hesitant at the $199 price, but we only use the navX-MXP for the IMU features, the Spartan Board has more of the RoboRIO breakouts which we don't currently need).
Unread 04-10-2016, 15:04
R.C.'s Avatar
I'll have a link up shortly on the wcp info.
R.C.
Unread 04-10-2016, 15:44
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
FRC #3476 (Code Orange)
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
The Spartan board has its own voltage regulators, locking PWM connectors, more exposed SPI, and 4 block DIO connectors. It is not an absolute need, but it provides lots of features that are very useful at the price point.
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
Unread 04-10-2016, 16:33
AlexanderTheOK AlexanderTheOK is offline
Guy
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
Having both used the navx and spartanboard on different teams I have to say that they are both excellent IMUs. Nearly no drift, and both are easy to use in programming.
Additionally though, while I can't speak directly for our wiring team, I do remember them being particularly pleased with the locking PWM pins.
Unread 04-10-2016, 16:35
FRC #4488
It sounds like both boards have very good accelerometer/gyro capabilities. I don't really know the details of the issues we were having over the defenses, but the SW guys definitely contacted the right folks about the issues and worked around them where possible. It was very possibly in the code and how we were using the values. I'm just the hardware guy :-).
Does anyone have a comparison of other features on the boards besides the gyro capabilities (assuming these are fairly similar)? Things like the number of extra DIO's, other breakout capabilities, locking connectors, etc.
Unread 04-10-2016, 16:46
R.C.'s Avatar
Link to Document
We'll have more info on our site.
R.C.
Unread 04-10-2016, 18:13
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
One very useful feature of the Spartan board is the "clip" on each of the PWM connectors. These latches bite into the connector of the PWM cable and prevent it from coming out, even if the robot takes a huge impact. Knowing that going over a huge bump or taking a big hit will neither mess up your gyro data nor cause a wire to come loose is a huge relief
EDIT. Here is a list of pros and cons for each system based on the data sheets and info I have on both. PLEASE let me know if I missed anything or if any information is incorrect!
Spartan Board:
Pros:
  • Less affected by impact.
  • Very useful encoder connectors (a single port on the board is used for both encoder cables)
  • Useful LED indicators for status
  • Cons:
  • More expensive
  • Single Axis only (Mounting to make sure the roboRIO is oriented to be parallel to the current plane is important!)
NAVX:
Pros:
  • Less drift over a match (though both gyros drift very little over an entire match)
  • Multiple Axis Gyro
  • Better Documentation (Though WCP seems to be working on that)
Cons:
  • More prone to drift due to impacts
  • Not as many useful features in terms of how ports are handled
Takin' a break.
Unread 04-10-2016, 19:03
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
As creator of the navX-MXP/MICRO I have to say that the Spartan connector breakout is very nicely done - kudos to WCP on that.
Moving beyond the side-by-side gyro accuracy comparisons which I understand are very similar, I'm not aware that the Spartan board has accelerometers or magnetometers on it. YMMV as to whether these features are valuable, but certain teams definitely use the accelerometer data to balance the robot, and the magnetometer to acquire initial compass orientation before the motors are energized at the start of a match.
Beyond the sensing capabilities, there's one key architectural feature in navX-MXP/navX-MICRO that definitely differentiates it - Simulaneous Multi-port data: using a dedicated 100Mhz microcontroller with simultaneous multi-port communication at 200Hz update rate (TTL UART, I2C, SPI and USB are all simultaneous).
The simultaneous multi-port data capability enables some very interesting features in a distributed processing environment, like connecting a navX-MXP/MICRO to both the RoboRIO and a separate video processor like the Raspberry PI or the nVidia Jetson. This allows the video processor to acquire IMU/1-millisecond resolution timestamp data from the navX at the instant each video frame is acquired, send that along with detection info to the RoboRIO, after which the Robot Control Software in the RoboRIO can look back into a 3D time history to correct the angles calculated by video processor to account for any motion occurring during the detection processor.
Note that this is a 3D time history of orientation, which includes not only changes to yaw but also tip and tilt; navX fuses gyro and accel data to yield a quaternion which represents 3d orientation.
The libraries and drivers to allow teams to easily add this capability to their robot control system are under development and are expected to be released by the time the 2017 season starts - as a free upgrade to existing navX-MXP and navX-MICRO customers.
Another useful feature this enables is to connect navX-MXP/navX-MICRO over USB to your PC to monitor it's behavior and/or stream sensor data to the PC disk at the same time it's connected to the RoboRIO.
Lastly, since I'm implying there's a dimension of apples and oranges in the comparison, one possibility I haven't heard discussed here is using the best of each. This configuration would use the Spartan board w/out the Gyro - for it's superior IO connector design - and then add a navX-MICRO sensor connected over USB for 9-axis, multiport orientation data.
Unread 04-10-2016, 19:35
FRC #1836 (MilkenKnights)
This past year 1836 did this so that we had freedom to place our roboRio in any orientation.
Unread 04-10-2016, 20:18
marshall's Avatar
Cool.
Unread 04-10-2016, 20:46
Software Mentor
AKA: Scott Libert
Hmm, perhaps that's also worth putting in the side-by-side comparison Ahad put together - the Spartan requires mounting perpendicular to the robot chassis (parallel to the Z-axis plane), whereas the navX-MXP can be mounted in any of 8 possible orientations. That ends up impacting RoboRIO mounting since both use the RoboRIO MXP port. The navX-MICRO - which doesn't use the MXP port - can be mounted independent of the RoboRIO.
