Go to Post CAD or it didn't happen - R3P0 [more]
Unread 04-10-2016, 21:16
Andrew_L's Avatar
Andrew_L Andrew_L is offline
#DriveSwerveEveryDay
AKA: Drübr Inc.
FRC #1323 (Madtown Robotics) #971 (Spartan Robotics)
Andrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud of
Re: NAVX vs. Spartan board
Originally Posted by slibert View Post
the Spartan requires mounting perpendicular to the robot chassis (parallel to the Z-axis plane)
[Citation needed]
Unread 04-10-2016, 21:39
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Hmm, perhaps that's also worth putting in the side-by-side comparison Ahad put together - the Spartan requires mounting perpendicular to the robot chassis (parallel to the Z-axis plane), whereas the navX-MXP can be mounted in any of 8 possible orientations. That ends up impacting RoboRIO mounting since both use the RoboRIO MXP port. The navX-MICRO - which doesn't use the MXP port - can be mounted independent of the RoboRIO.
Scott, thanks for the suggestion! I made an edit to the list to add in your points.
Takin' a break.
Unread 04-10-2016, 22:32
Jared Russell's Avatar
Taking a year (mostly) off
Both of them have been used successfully by many teams, and you can't go wrong using either for helping determine your robot's heading.
Honestly it is really hard to judge a gyro by its spec sheet - you always end up with apples vs. oranges (ex. the ADXRS has *excellent* tilt and vibration rejection specs, whereas the MPU-9250 can use its linear accelerometers for tilt rejection), and various manufacturers may be more or less conservative about the relationship between their specs and their actual median product performance.
When it comes to pure yaw performance, I'm a bit surprised that nobody has done a benchmark yet (Put both gyros on the same robot, calibrate right before starting, drive around for 2 minutes, return and manually align the robot to exactly the same angle...repeat for N trials). I'd be shocked if there was a significant difference, to be honest.
Of course, there's no doubt that NAVX wins hands down in pitch, roll, linear acceleration, and direction of gravity measurement though.
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Originally Posted by Andrew_L View Post
[Citation needed]
Per the ADXRS453 datasheet, the Gyro on the gyro-enabled version of the Spartan board is single-axis, and is the SOIC_CAV package designed for yaw rate sensing. I haven't come across any Spartan board mounting instructions, but if we thus assume the purpose of the ADXRS453 is to be a yaw rate sensor, then any mounting configuration in which the sensor is not parallel to the FRC field surface will result in integrated yaw angles which include an error proportional to the offset angle from parallel. For instance, if the board is mounted vertically, the sensor would be measuring a "tip" or "tilt" angular rate rather than yaw. This is as compared to a triaxial gyro which can measure yaw rate even when mounted vertically.
If you think this is incorrect, please let me know.
Unread 04-10-2016, 22:33
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
I'll put in that we had no issues with NavX heading getting off due to defenses. During our autonomous, our robot was able to reliably and precisely get itself to the tower (using the NavX and encoders on a tank drive for dead reckoning), even after slamming down over the rock wall.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 04-10-2016, 22:55
That is correct. The roboRIO needs to be horizontal.
We developed the Spartan Board mostly to solve brownouts and latching connectors. If it hadn't been for the brownout problems with the roboRIO, we would have likely developed the board only for 971 and not bothered to sell it. The regulators brown out right about when the roboRIO CPU browns out.
We've been using the ADXRS453 for a number of years, and have been impressed with it. Once you are making a board with a bunch of active circuitry, adding a gyro is easy. I might have picked a different gyro if I were to start over today.
One of the main drivers for selling the board was because there was enough interest from our friends in the board that we couldn't continue to fabricate enough of them each season. By selling it, we were also able to get it approved by FIRST, and add PWM pass-throughs. Selling the board has honestly been a lot of work... RC and WCP have been a huge part of figuring out how to build the boards in quantity and to sell them.
Unread 04-10-2016, 22:56
Andrew_L's Avatar
AKA: Drübr Inc.
My apologies, I was assuming you meant to say either of the Spartan Boards could not physically be mounted in other planes. I didn't want teams getting the wrong idea that they couldn't mount a Spartan Board without gyro any direction other than parallel with the floor.
Unread 05-10-2016, 00:24
FRC #1836 (MilkenKnights)
The navX-MXP can also be mounted independently, assuming you use USB to connect to the roboRio
Unread 08-10-2016, 11:38
bretcobrageek's Avatar
bretcobrageek bretcobrageek is offline
FRC #4488
bretcobrageek is an unknown quantity at this point
Thanks everyone for the great comparisons and feedback. As I suspected, both boards are great at the basics but do have some differences which may make a difference depending on what you want to do or how you want to use their capabilities. The idea of the base spartan board with the Navxmicro is really intriguing. I'll consult the rest of the team and see where we want to go for this season.
