Go to Post I'm sure there aren't a bunch of rule makers sitting in a board room discussing "What rule can we change now to mess with the teams' heads?" Lets all just sit back and enjoy the regionals! - Rick [more]
Unread 04-10-2016, 22:56
Andrew_L's Avatar
Andrew_L Andrew_L is offline
#DriveSwerveEveryDay
AKA: Drübr Inc.
FRC #1323 (Madtown Robotics) #971 (Spartan Robotics)
Andrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud of
Re: NAVX vs. Spartan board
Originally Posted by slibert View Post
Per the ADXRS453 datasheet, the Gyro on the gyro-enabled version of the Spartan board is single-axis, and is the SOIC_CAV package designed for yaw rate sensing. I haven't come across any Spartan board mounting instructions, but if we thus assume the purpose of the ADXRS453 is to be a yaw rate sensor, then any mounting configuration in which the sensor is not parallel to the FRC field surface will result in integrated yaw angles which include an error proportional to the offset angle from parallel. For instance, if the board is mounted vertically, the sensor would be measuring a "tip" or "tilt" angular rate rather than yaw. This is as compared to a triaxial gyro which can measure yaw rate even when mounted vertically.
If you think this is incorrect, please let me know.
My apologies, I was assuming you meant to say either of the Spartan Boards could not physically be mounted in other planes. I didn't want teams getting the wrong idea that they couldn't mount a Spartan Board without gyro any direction other than parallel with the floor.
