Go to Post To me, my mentors are the Father figures. They guide me through each and everything (even if its not robot related), and try to make it as fun as possible. - RoboMadi [more]
Unread 04-10-2016, 10:56
Knufire Knufire is online now
Transparent Air Tank
Does anyone know/have a source for a transparent air tank? I've been looking for one for a different competition; they want to be able to see within the tank to make sure we're not adding anything to the air. It'll be storing air around 100psi, so anything rated for 120psi or more should be fine. Volume would be around typical FRC usage as well (~500mL).
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 04-10-2016, 11:31
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: Transparent Air Tank
Would an aquarium work?
Hi!
Unread 04-10-2016, 11:37
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
You're not going to find many of these, sadly. There aren't many clear plastics that play nice with high pressure. You can MAKE one of transparent ABS, but that has a nasty habit of exploding under too much pressure.
Which competition is this? Would a glass or plastic porthole into the tank be acceptable? A sight glass is a very easy way to add visibility to a process. They're designed to add a visible port to watch oil levels in systems where that's required.
https://www.amazon.com/Compressor-Fi.../dp/B00880DXQC
https://www.amazon.com/Thread-Diamet...YG6E 2RZQG0H7
https://www.amazon.com/W-Anderson%C2...7KC8 D5N41ADP
Last edited by Wren Hensgen : 04-10-2016 at 11:46. Reason: Added some better examples
Unread 04-10-2016, 11:40
AKA: Wren Hensgen
If you're talking about a standard rectangular tank, you'll just blow out the side walls because of the pressure. If you're modifying something, you'll have to be extremely careful, as the glass is not pressure rated, and is likely to shatter under stress.
Unread 04-10-2016, 11:46
Shell Ecomarathon. The tank would be providing pressure to the fuel injector for a small engine. The rationale behind the rule is to ensure that we're not premixing fuel with the air, though the implementation seems to be poor.
Originally Posted by SHELL ECO-MARATHON
2017 OFFICIAL RULES. CHAPTER I
b) It is permitted to pressurise the liquid fuel tanks, in order to feed the engine, only under the
following conditions:
i. Pressurisation is done by means of a translucent compressed air bottle fitted with a safety
valve set to 5 bars maximum – or the lower operation pressure of the vehicle system.
Most teams seem to be jerry-rigging something out of a 20oz soda bottle; seems less safe to me than just letting use COTS storage tanks.
Unread 04-10-2016, 11:48
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
you could make one, using aluminum end caps, and Lexan™ round tube, sealed with O rings. We used them on our underwater robots (link below), you'd have to do the engineering necessary to make sure it's safe, of course.
Unread 04-10-2016, 11:51
AKA: Wren Hensgen
I would absolutely just put a sight glass or two into the bottom, so they can see that there's no liquid in the tank. See my last post for some examples.
Unread 04-10-2016, 13:49
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
I have one of these on my compressor to keep moisture out of nail guns.
You can plumb it directly into the system and not have to modify the tanks.
https://www.amazon.com/Water-Separat...sor+water+trap
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 04-10-2016, 14:56
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
I had the same idea. It would also filter water out, though water may look like fuel...adding a transparent section of pipe may also work.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 04-10-2016, 15:23
RoboChair's Avatar
AKA: Devin Castellucci
2 liter bottles are good to about 120psi before failure, 20oz is probably a fair bit higher. You can do some destructive tests first. I would suggest clear polycarbonate tubing which you can buy from McMaster as you can use pipe fittings with it.
Alternatively just use a long piece of clear hose.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 05-10-2016, 00:08
Bob Steele's Avatar
Bob Steele Bob Steele is online now
On the RIBMEATS bandwagon....
AKA: Bob Steele
Depending on volume you might try a soda preform. See below
https://www.amazon.com/Soda-Bottle-P.../dp/B008MB1QNY
Unread 05-10-2016, 09:15
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
I too was thinking along these lines. Most safety standards with regards to pressure vessels want a 2.3 Safety factor, so if the burst pressure is 120 PSI, then filling up to 50 PSI would be the responsible thing to do. I know for water rocket competitions, a lot of folks regularly fill them to 70 PSI (about a 1.5 SF).
The stresses should be lower on a 1 liter bottle which may be able to get a higher rating.
Unread 06-10-2016, 11:14
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Many air filters are similar to the water separator already mentioned, you could remove the filter if needed.
Andy Brockway
Team 716, The Who'sCTEKS
