Go to Post In the end engineering is what happens between your ears, not what you build with your hands, not what a machine spits out. - KenWittlief [more]
Unread 06-10-2016, 16:25
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: pic: 24 Years of Game Pieces
I like this table, but I have one problem with it. In both the size and weight categories, there are big differences within the categories and crossover within the categories. For example, I would say that a stack of totes is much larger than a trackball, even though the trackball is labeled XL and the totes are only L. If you were referring to only one tote, then I would definitely not say that it weighs the same as a tetra. Maybe for better clarity, you can give approximate weight and volume as a number instead of a category. Just a suggestion
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
