Go to Post Purpose over pimpness is a policy that we are trying to adhere to. - santosh [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 06-10-2016, 15:40
loading a COO file into Python
Greetings Python gurus.
I'm looking for a better (faster) way to load a plaintext COO (row,column,value tuple) file into Python. The values are all integers.
File Aijv.dat is a ~7.5 MB plaintext file in COO format representing a
178420x2696 sparse matrix with 535260 non-zero entries.
Here's a portion of code showing Python taking almost 19 seconds to load Aijv.dat:
Python 2.7.5 (default, May 15 2013, 22:43:36)
[MSC v.1500 32 bit (Intel)] on win32
>>> import numpy
>>> import time
>>> import scipy
>>> import scipy.sparse as sp
>>> import scipy.sparse.linalg
>>> start=time.time()
>>> Aijv = numpy.loadtxt('Aijv.dat', 'int')
>>> time.time()-start
18.844000101089478
The exact same file takes only 5.5 seconds to load in Octave:
GNU Octave, version 3.6.4
+ tic;
+ Aijv = dlmread ('Aijv.dat');
+ toc
Elapsed time is 5.547 seconds.
Unread 06-10-2016, 16:34
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: loading a COO file into Python
Write a native module to do it faster?
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 06-10-2016, 16:47
I could certainly do that as a last resort if Python doesn't already have a built-in function to do it.
Long experience has taught me to explore the capabilities of the language to avoid re-inventing the wheel.
Unread 06-10-2016, 18:00
tjf's Avatar
tjf tjf is offline
FIRST Year, Best Year
AKA: Tim Flynn
FRC #1257 (Parallel Universe)
Rookie Year: 2016
tjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to behold
The simplest solution is often the easiest one. I'd personally just parse it myself and read line by line with a file reader, parse into an object and add each one into an array.
My 2c.
1257 (2016) - Student
1257 (2017) - Business Mentor (up in your business!)
KD2KRT
Unread 06-10-2016, 18:12
Here's a link to the 7zipped Aij.dat file.
If your solution is the simplest and easiest one, please show us how you propose to "parse it myself and read line by line with a file reader, parse into an object and add each one into an array".
Unread 06-10-2016, 23:36
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Apparently pandas has something for this that outperforms numpy.loadtxt?
http://wesmckinney.com/blog/a-new-hi...ne-for-pandas/
And here:
http://akuederle.com/stop-using-numpy-loadtxt
Unread 07-10-2016, 00:36
Thanks Dustin.
I'll try that.
Unread 07-10-2016, 09:12
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
I'm curious as to why you're using Python in the first place if performance is a concern.
Unread 07-10-2016, 10:12
Well this is a bit unexpected. Looks like I get to play the role of Python guru momentarily
Python is supported by an immense library of highly optimized math and science routines. It's as fast (and faster in some cases) as Matlab/Octave, and in some cases actually easier to use.
It's free, has a large installation base, and the code is quite readable... all of which makes it a convenient vehicle for sharing solutions... such as how to efficiently compute World OPR or other metrics using both min |Ax-b|2 and min |Ax-b]1 etc.
Unread 07-10-2016, 15:17
vScourge's Avatar
vScourge vScourge is offline
Videogame Developer
AKA: Adam Pletcher
FRC #4096 (Ctrl-Z)
vScourge is on a distinguished road
This only took 3.4 seconds to run on my Win 8.1 system.
import os
import time
time_start = time.time( )
data = [ ]
for line in open( r'D:\temp\Aijv.dat', 'r' ):
	data.append( [ int( x ) for x in line.rstrip( ).split( ' ' ) ] )
print( '{0:.2f} secs'.format( time.time( ) - time_start ) )
Unread 10-10-2016, 14:29
Thanks. That's quite an improvement.
It took ~5.3 seconds on my 10-year-old PentiumD Win32 machine:
>>> data = [ ]
>>> for line in open( r'k:/data/Aijv big data.dat', 'r' ):
...     data.append( [ int( x ) for x in line.rstrip( ).split( ' ' ) ] )
>>> time.time()-start
5.296999931335449
>>> start=time.time()
>>> Aijv = np.loadtxt('k:/data/Aijv big data.dat', 'int');
>>> time.time()-start
18.858999967575073
Also:
>>> start=time.time()
>>> Ajiv = np.transpose(Aijv)
>>> time.time()-start
0.0
>>> start=time.time()
>>> datajiv = np.transpose(data)
>>> time.time()-start
3.937999963760376
Why does it take so much longer to transpose data than Aijv ?
BTW, the benchmark time on my machine appears to be about 0.5 seconds. That's the total time it took a compiled Win32 app to read Aijv.dat into a transposed array.
Unread 10-10-2016, 14:55
WOW. Pandas is FAST.
Just ran it on a slower machine and it loaded Aijv.dat in less than one second.
You are my Python guru Dustin
Unread 10-10-2016, 21:00
virtuald's Avatar
RobotPy Guy
Glad to help.
My guess is that because data isn't already a numpy array, it has to do a lot of work to convert it to one first, and then do the transpose operation. If I'm correct, a second transpose on the result of the first transpose would be very fast, similar to the operation on Ajiv.
If I understand what transpose does, it most likely is just moving the pointers to the various axes around -- thus why it's so fast. My understanding of how numpy arrays work is that they try really hard to not actually move data around, but many common operations can be done by just creating/moving various pointers around.
