Re: Severe RobboRIO Error
How are you powering the RIO? Power supply? Battery? What is connected to the RoboRIO other than power and data cables?
I would recommend connecting the DS computer and roboRIO using a USB cable. If that doesn't immediately work, go to the Diagnostics tab of the DS, second from top on the left side, and determine if the DS can ping the robot successfully. Ensure that firewalls are disabled on the laptop.
Once you get this working, you can use it to correct the ethernet and then wifi. Greg McKaskle |
Sorry for the late reply. |
