Go to Post As everyone knows, our students don't actually design or build the robot, so to make it look like they were working on it for the video, we hid cookies inside the unfinished frame and turned them loose. It looks believable. - Mike Soukup [more]
Unread 08-10-2016, 03:10
dardeshna's Avatar
dardeshna dardeshna is offline
Build Captain
AKA: Devin Ardeshna
FRC #0008 (Paly Robotics | Team 8)
Rookie Year: 2015
dardeshna is an unknown quantity at this point
Solenoid delay
Hi all - we are currently experiencing an issue where there is significant delay in solenoid activation. We think that the delay is eliminated by a completely fresh battery, however even a slightly discharged battery which works for the rest of the robot seems to cause delays. Another possible explanation is a lack of pressure, although we usually have a good 40psi in the system and still have delays. Has anyone experienced solenoid delay along these lines before?
We are using the solenoids found here - http://www.vexrobotics.com/vexpro/pn...manifolds.html
Unread 08-10-2016, 11:52
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
jimbo493 is on a distinguished road
Re: Solenoid delay
Are you noticing a delay from when you fire it, and seeing the light on the solenoid change, or when the piston is extended?
What kind of piston are you using, could you provide a picture so we can have a clearer picture of what's going on? I doubt that it has anything to do with the battery myself.
FTC Student 2011-2012 FRC Student 2012-2016
FIRST Alum/Quasi-Mentor 2016-present
