Go to Post last year I wanted to electrically charge our frame, then cover the whole bot in tape and say it was for insulating purposes. Then I settled down and read the rule book. - russell [more]
Unread 09-10-2016, 12:58
Billfred's Avatar
Billfred Billfred is offline
Re: pic: Team230 Damaged Frame Rail
Originally Posted by chrisfl View Post
Thank you all for the insights. Our team has been looking into trying a west coast drive this fall and this really helps. What other tips or tricks do you guys have in regards to west coast drive?
Whether 4901's design really is or isn't WCD is a fair question (we supported both ends of the shaft out of concern for the game), but we were running chain-in-tube as many WCDs do.
1) When dead-spacing chain, the term "designing an even number of links" means "2, 4, 6, 8" not "integer". Use a calculator; we like this one.
2) If you must run half-links because you ignored #1 or had a very good reason, make it the kind that don't have the little retaining pin you bend. That pin will be busted off by the other chain, and you will throw it, and you will be fishing new chain into your tube. (McMaster-Carr sells the good stuff.)
3) Dark Soul tool is so much better for making complete chain loops than any master link. Even the normal master link will, invariably, be busted off and you will throw a chain.
4) Design your drivetrain so you can get the main rail off without too much fuss. Riveting your belly pan every inch or so is too much fuss. (This was our greatest issue once we sorted out the chain; haven't designed a better plan yet.)
5) Drive your drivetrain early and often, to make sure your teething problems happen at home and not at your event. (You should be doing this anyway, but especially when you're doing a new-to-you drive system.)
Unread 09-10-2016, 17:07
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Do you have any preliminary thoughts on how to design a belly pan such that the main rails can be taken off easily? I think that's a tough balance to find, considering that a belly pan has to be mounted properly to impart torsional strength to the chassis. Do you know of any teams that have worked this out?
Unread 09-10-2016, 17:17
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
2590 Nemesis would be a great team to chime in on this. I know in 2014 and 2016 their rails were designed to be removable.
1058 PVC Pirates 2016 - xxxx
Unread 09-10-2016, 17:59
Those are some gorgeous drivetrains. You can see a lot of thought when into many critical factors. The staggering of the rivets to not interfere with the runs of chain, the flexible coupling on the back axles for encoder mounting, and the way they've done the tabs in the belly pan are things I'll have to remember.
Unread 10-10-2016, 10:57
Thayer McCollum's Avatar
Thayer McCollum Thayer McCollum is offline
[Insert Name Here]
FRC #0159 (Alpine Robotics)
Rookie Year: 2015
Thayer McCollum will become famous soon enoughThayer McCollum will become famous soon enough
https://drive.google.com/open?id=0B4...Q3RxV Wo2QTVJ
So I'm wondering if more teams do this? ^^ It's hard to tell from the picture but we welded thick wall aluminum tube (can't remember exact thickness) into the rail and then machined the weld flat and used a boring bar to achieve the diameter we wanted for the bearing. I feel like this would have prevented the damage to the rail in the original picture. What are your thoughts? Why don't other teams do this? Is it unnecessary? Do I just have no idea what I'm talking about? I am very curious.
Unread 10-10-2016, 11:17
Billfred's Avatar
I think it falls under "valid, but overkill for all but the most brutal of games". If wall thickness was a concern, doing something like 148 did with reinforcement plates at the bearings is probably a simpler method for most.
Unread 10-10-2016, 11:49
Chris is me's Avatar
AKA: Pinecone
Teams usually use 1/8" wall aluminum tubing for their drive rails, which prevents the problem. Some teams use bearing blocks or shims to provide even more material support to the bearing than the 1/8" wall tubing, which is safer. It's quite uncommon to use 1/16" wall tubing for drive rails at all, and I generally think it's not worth the weight savings to do so.
Your solution is essentially a welded-in bearing block, which seems overkill, especially compared to the various other bearing block solutions teams can come up with that aren't so tricky to machine and install. It'll work, but there are better uses of your time, and it'd be better to just not use 1/16" tubing for supporting bearings directly.
Unread 10-10-2016, 18:36
[Insert Name Here]
Rookie Year: 2015
So I suppose I should have clarified. I agree that structurally the tube concept is overkill. It adds support the rail doesn't really need. We did this because we felt that just pressing the bearings into the rail would cause them to fall out easily. Is that not the case? Does 1/8" wall easily support bearings without them falling out? Because in my experience that hasn't happened. If someone could tell me how to put the bearings in without them falling out I would be happy to learn. (Because those tubes really sucked to put in...)
Unread 10-10-2016, 19:45
Billfred's Avatar
For us:
1) Machine the hole just slightly undersized. Adjust it lightly when it's necessary.
2) Minimize axial slop on your axles. If your wheels can't slide back and forth on the axle, it makes it harder for it to wiggle the bearings too. (E-clips help with this.)
Unread 10-10-2016, 22:45
Joe Finkel Joe Finkel is offline
FRC #0369 (High Voltage)
Joe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura about
1. RIM THE HOLE.
2. E-CLIP
3. RETAINING RING
4. SCREW AND A WASHER AT THE END OF THE AXLE
Unread 10-10-2016, 23:04
AKA: Pinecone
Bearing retention really has very little to do with the wall thickness of the material the bearing is pressed in. How the hole is sized is the biggest factor, really. Machine the hole a thou or two undersize for a nice press fit, but not so much under the bearing will seize. If you can't do this, using green loctite (gap filling) will help hold the bearing press fit in securely. Otherwise, you can use the hardware on your shaft to hold your bearings in (spacers, etc).
I would definitely not recommend an E-clip to do this if the E-clip is between loads, only on the end. And even then a snap ring is simply the better tool for the job.
Unread 10-10-2016, 23:05
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Originally Posted by MamaSpoldi View Post
Why are the holes offset from each other? It appears that the inner hole is at least 0.125" further to the left as pictured that the outer hole showing the damage.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 11-10-2016, 09:25
AKA: Pinecone
I'm fairly sure that's just the camera angle here; their drivetrain was a fairly normal WCD.
(haha, get it, "normal", I crack myself up)
Unread 13-10-2016, 10:33
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
I can't speak for 230, but 4901 never replaced any of their 1/8" wall tubing through two competitions and demos. The final exam would be next weekend at SCRIW.
After the rest of a long season... and off-season events... and community events, I can report that the replaced tubing has held up great.
