Go to Post Read the rules. And then read the rules again. Then, get together as a group and read the rules together. - Knufire [more]
Unread 11-10-2016, 17:26
mattoreo310 mattoreo310 is offline
FRC #4012
mattoreo310 is an unknown quantity at this point
Re: cRio refuses to work with newest driver station
Originally Posted by Mark McLeod View Post
What Java version are you attempting to use on the old 4-slot cRIO?
The version used for the roboRIO is not compatible with the cRIO which used a different/older version.
I believe v52 is the correct FRC image for 2014.
You can use the cRIO if you still have an old original Java user program installed on it, but you won't be able to make modifications.
Or if you still have an installation of the older cRIO Java version on a PC that can be used.
Otherwise, LabVIEW is the only really supported cross-compatible language.
Well I'm not sure what java version the v52, I believe I'm using 6 to build the program though. Do I have no choice but to use labview if this is the case?
