Go to Post The robot is NOT a lie. - Rick TYler [more]
Unread 11-10-2016, 17:29
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Gates belt theroy questions
After using the WCP belt calculator and learning the math behind it from the Gates belt theroy book I found on discrepancy that caught my attention. The calculations were for a HTD 5 180 tooth timing belt between two 24 tooth pulleys.
The math that I ended up with using the math in the Gates theroy book was:
pitch*(Belt teeth - pulley teeth)/2 = c to c distance
5mm*(180t-24t)/2 = 390mm
The under lying equation from WCP seemed to be:
pitch*(Belt teeth - pulley teeth)/2 +0.001"= c to c distance
So my question is what is the point of that extra .001" added to the distance?
*Sent from my phone(quickly during class...)*
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 11-10-2016, 17:41
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
Re: Gates belt theroy questions
Pretension. Make a tighter belt. Prevent belt from flying off?
Most FRC teams can't even manufacture to the tolerance of 0.001" anyways...
Formula SAE is now the thing I do. #becauseRacecar
But I'll still be a mentor for like, forever.
Check out what I'm up to: http://ppi.ddns.net/blog
"So, wait, what kind of engineer are you? Mechanical? Electrical? Software?"
"Yeah pretty much."
Unread 11-10-2016, 17:42
Billfred's Avatar
Billfred Billfred is offline
Generally, additions like that (or to the C-C distances on gearboxes) are made to account for manufacturing tolerances. By fudging it a tiny bit large, you give yourself room for error while still getting a tight belt. (If it was too tight, you could always fudge the hole back a little and survive. It's far harder to make that happen when it's too loose.) That particular number would come from the calculator maker's past experiences, and may vary for other applications.
I'd say the number of teams that can make that happen grows annually (and maybe beyond the FRC growth rate) as precision manufacturing gets cheaper and more widespread. Whether that ability is in-house and/or whether they take full advantage of it is another topic.
Unread 12-10-2016, 13:23
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
See page 182 in the Gates Power Drive Design manual. The standard pre-tensioning center distance should be in the .02 to .03 inch range for most HTD or GT3 belting sizes used in robotics.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 12-10-2016, 16:17
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
Hell no, that is significantly overtensioned. If you take a closer look at that document you'll see that they aren't referring to pretensioning distances at all:
Since fixed center drives are not recommended, center distance allowances for a Gates PowerGrip® belt drive are necessary to assure that the belt can be installed with-out damage and then tensioned correctly. The standard installation allowance is the minimum decrease in center distance required to install a belt when flanged sprockets are removed from their shafts for belt installation. This is shown in the first column of Table 4. This table also lists the min-imum increase in center distance required to assure that a belt can be properly tensioned over its normal lifetime.
The table immediately below that you got the 0.02" and 0.03" numbers from refers to the minimum amount adjustability (think versablock) in c-c distances that they recommend so that the belt is easy to install and so that it can be tensioned as it stretches over time (as timing belts often do in industrial applications).
In FRC, however, fixed c-c distances work great because of the limited run-time of our robots, and are generally designed to be exact or a couple of thousandths large.
Unread 13-10-2016, 01:42
InFlight's Avatar
AKA: Jim
The Nominal Center Distance is for very light loads, it is a zero belt tension condition. Also consider that belt lengths have tolerances (typically +/- 0.08 inches for short belts). With a Drive Train with two CIMs near stall torque; you will skip teeth if you don't have adequate tension. The only options are a tensioner or extra length in the Center Distance to insure a preload.
The belts are normally rated for 8000 hours, so run time isn't a FRC issue. Adequate Tension for the required load and speeds is a concern for reliability.
Unread 13-10-2016, 02:35
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Can you give a reference on this? I don't see anything on the VEX website. If I were to buy a belt on SDP-SI, they give tolerances in the range of 0.02 in. Which belts or suppliers are you talking about?
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 13-10-2016, 08:26
InFlight's Avatar
AKA: Jim
That's the Gates specificifation. It would still apply to GT3 and their HTD. The HTD patent is expired, so there's lots of aftermarket HTD belts. How more or less accurate second source suppliers are is unknown. But for as cheap as these belts are now, I wouldn't expect tighter tolerances.
Unread 13-10-2016, 10:24
Basel A's Avatar
AKA: @BaselThe2nd
Their GT3 Belt Drive Design Manual lists C-C belt length tolerances on the order of 0.01 in
-Paul Copioli
Unread 13-10-2016, 12:02
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I believe 2791 just runs direct C-C with no center distance addition going off what Chris is Me says. Although the tolerance may be 0.02", realistically it could be much tighter than that.
Unread 13-10-2016, 12:07
AdamHeard's Avatar
Lead Mentor
Not super scientific, but we generally run .005" over on our loaded belt runs. Even that is in the range where it starts to get hard to install in an exact C-C application.
Also.... Theroy Jenkins!
Unread 13-10-2016, 12:18
Chris is me's Avatar
AKA: Pinecone
Yup, we don't add anything to the center distance and it "just works".
With regards to the specs - the center distance equations are the same. You'll notice the WCP calculator has a field called "center distance adder" that is set to .001 by default - that is where the term comes from. Leaving this at one thou is fine if you want. Doesn't seem to make much difference either way. If you needed to be within one thou of a specific exact distance for belts to work, you wouldn't be able to run them with exact centers anyway because almost nobody holds those tolerances in FRC.
As for the rest of the specs - keep in mind they are referring to mechanisms with far higher runtimes than FRC things. They are very conservative.
Unread 13-10-2016, 16:04
Munchskull's Avatar
Team Role: CAD
Thank you for all of the information. Would the pure calculation or adding a few thousandth to the distance yeild a drive that would be less likely to snap a belt?
Also I have heard that mixing different belt with htd5 pulleys can result in less failure than just using HTD 5. Is there any merit to that?
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 13-10-2016, 16:42
AKA: Pinecone
Once you add enough distance, you start to over-tension the belt, and you risk failure that way. Once you remove enough distance, you risk ratcheting.
5 thou or less added seems like it would be fine.
Using GT2 belts with HTD pulleys is slightly stronger than HTD / HTD, but weaker than GT2 / GT2. I don't think you need to do this - if your belt strength is marginal enough for this to make the difference you don't have a big enough safety factor.
Remember, 15mm wide for 24T pulleys in a drivetrain.
Unread 13-10-2016, 18:02
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
https://www.gates.com/~/media/files/...ure-102005.pdf
This brochure from Gates does a pretty good job of explaining what belts interface with what pulleys. The one thing it doesn't include is the GT3 series of timing belts, which interface with GT2 pulleys.
