Re: FRC code search: a great project for someone to start
Here's a basic first pass at it in node.js with mongodb: https://github.com/erikuhlmann/grepfrc
Unfortunately I haven't had the patience to let it finish indexing all the code repos and I'm not sure how big that causes the database to become. |
Since most people use git to manage robot code, there may be an easier way to go about this.
1) Allow people to submit their code. Take the appropriate deets (team #, year, primary lang) if applicable (remember, non-teams can have FRC code too ).2) Store this on a database, along with a link to the git repo 3) Index it by downloading the latest commit (--depth=1) of this repo somewhere known. Keep a watch on all repos, updating if needed maybe once per day. (You could do a deeper depth but HDD use would skyrocket if you plan on scaling at all) 4) Just pass in your query as a git grep. If anyone is willing to do this project and wants some extra information about the implementation of the above, let me know. GLHF |
More serious suggestion would be to enable teams to link to GitHub projects for specific robots on TBA. That should provide 80% functionality for 20% of the effort and I'm pretty sure it would work the same way the existing social media extensions work for TBA.
TBA can already link GitHub profiles to teams. Do you think that is good enough, or would it better to build an association between (team + year) and github repo(s)?
The latter is good (and you could pull much of that data from what I've already got on FIRSTwiki), but wouldn't meet the goal of 'grepcode for FRC code'.
I believe the goal is to grep code usages. For example, "show me examples of the usage of ControllerPower" would just be a grep of "ControllerPower", not necessarily "Show me ####'s code for their 2016 Robot". I believe you can do this with Github's search, but only one repo at a time.
#7
![]() However, it would be useful to have that information on TBA too. |
#8
Or use an actual database engine's full text search, which should be far more efficient.
Btw, when I tried searching for usages of WPILib classes with my mongo/node implementation, I found more than a few top results being the source for that WPILib class, since it seems many teams like to keep entire copies of WPILib in their repos. I wonder if there's a way to filter those out. |
#9
If you wanted to be super fancy, you could split by subroutine, and hash those (excluding whitespace). |
#10
Git grep also has the advantage that you can call it with `git rev-list --all` to search for occurrences of a string over all commits, ever. Likewise, you can grep subdirectories, discounting any directories that resemble that of the wpilib source. |
