Go to Post The key is to get the WHOLE TEAM to understand that you are designing and building a robot, which is a complete system - not just a collection of mechanical assemblies stuck together. - SteveGarward [more]
Unread 10-12-2016, 09:11 PM
MikePerreman's Avatar
MikePerreman MikePerreman is offline
FRC #0247
MikePerreman is an unknown quantity at this point
network tables and the raspberry pi
well, the title is self explanatory, anyone know how to include the network tables, and more importantly, get them to work "properly"
Programmer - A creature known for converting Caffeine into Code.
Unread 10-12-2016, 09:35 PM
Jchau Jchau is offline
1414 - Programmer | Engineer
FRC #1414 (iHOT Robotics)
Rookie Year: 2015
Jchau is an unknown quantity at this point
Re: network tables and the raspberry pi
I am not sure if you have seen this yet: https://github.com/robotpy/pynetwork...master/samples.
It pretty much has everything you need to know to use the network tables on the raspberry pi, from installation to sample code.
Unread 10-12-2016, 09:37 PM
BenBernard BenBernard is offline
FRC #5687 (The Outliers)
Rookie Year: 2015
BenBernard is an unknown quantity at this point
There are a few threads on the subject here, but if you just want code, please feel free to look at our 2016 pi-tracker in github: https://github.com/frc5687/pi-tracker.
Also included is the networktables jar file.
There's not much documentation on github, but the code itself should be fairly clear. You're also welcome to PM me with questions.
Unread 10-12-2016, 09:40 PM
Rookie Year: 2015
I assumed java...but of course if you were looking for python, go with jchau's reply above!
Unread 10-12-2016, 09:49 PM
Rookie Year: 2015
If you do choose to go with python, you can get more information about installation as well as the API reference here: http://pynetworktables.readthedocs.io/en/latest/.
Unread 10-13-2016, 06:15 AM
FRC #0247
alright, thanks for the quick info, ill give this a shot!
Unread 10-14-2016, 03:20 PM
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Python example: https://github.com/GarnetSquardon490...or_shutdown.py
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 10-19-2016, 08:03 PM
bankst's Avatar
bankst bankst is offline
FRC #0832 (OSCAR)
bankst is an unknown quantity at this point
Here's 832's brand new OpenCV code using python and pynetworktables:
https://github.com/oscarrobotics/VisionOnPi2016
If you're using the Pi for Vision Processing, you can also just copy the whole thing, as long as you follow the instructions in the README
Unread 12-12-2016, 11:52 AM
kmckay's Avatar
kmckay kmckay is offline
FRC #5401 (Fightin' Robotic Owls)
Rookie Year: 2015
kmckay will become famous soon enough
I see its been updated to eliminate NT and use UDP, did the NT code work? Any landmines that you recall?
Unread 12-12-2016, 03:44 PM
Rookie Year: 2015
We encountered substantially more lag with NetworkTables than with straight UDP. Plus, we would occasionally see odd behavior in the NT version that may or may not have been caused by NT bugs. Values would change at unexpected times, etc. I think we were just pushing more data through NT than it was designed for, so rather than debug we switched to UDP and the problems went away.
Unread 12-12-2016, 03:47 PM
kmckay's Avatar
Rookie Year: 2015
Do you have a good source of code for reading the UDP into a robot program?
Unread 12-12-2016, 03:58 PM
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Interesting. With our vision solution, we were fine with NT, and we were even able to use PID control on it.
Unread 12-12-2016, 05:30 PM
Rookie Year: 2015
I'll let you judge whether it's "good" or not, but we do have both ends of the UDP communication in our github.
On the pi, we run pi-tracker and communicaton with the rio is through RobotProxy. RobotProxy starts a thread to listen for incoming UDP packets from the rio, and expose the incoming values. It also provides the Send method to send updates to the rio.
On the rio, the robot code uses the PiTrackerProxy exactly the same way: it starts a thread to listen for incoming packets from the pi while providing the collect method to send packets to the pi.
Note that the reason for this complicated mechanism was to more precisely correlate the timing of images to the position the robot was in when the picture was taken. For more on this, see Team 254's video and presentation.
We then compute a new "target" pose based on the image and pose when the image was taken, and use PID to get us there.
Unread 12-12-2016, 08:54 PM
BrianAtlanta's Avatar
BrianAtlanta BrianAtlanta is offline
FRC #1261
BrianAtlanta has a spectacular aura aboutBrianAtlanta has a spectacular aura about
The biggest drawback to NT, is the update frequency, the fastest you can configure them to update is 100ms. Does that hurt, depends on how you use it. Faster doesn't always mean better. But when you add in the delay of the co-processor to process the image, and include in the NT delay, it can quickly become a problem.
In our code, NT was fine, but UDP would have been better and reduced oscillation during targeting. But with NT we could fire in about 3s (turn and elevate), and hit 80-90%. We will look at UDP in the future, but NT are a good V1.0 option, just understand the limitations.
Unread 12-13-2016, 08:49 AM
kmckay's Avatar
Rookie Year: 2015
I see in the link the NT receive, do you have your code from the pi to send? Did you have any trouble loading NT libraries onto the Pi?
