Go to Post Short answer, the GDC has ruled it legal explicitly through Q&A, implicitly through Q&A, and implicitly through the Manual. - EricH [more]
Unread 15-10-2016, 12:56
Jayd009's Avatar
Jayd009 Jayd009 is offline
AKA: Jonathan
FRC #4468 (Fernbank LINKS)
Rookie Year: 2016
Jayd009 is on a distinguished road
GRIP Deploy Not Working
Hello everyone,
My team is trying to use GRIP on our Raspberry Pi 3 to run the vision code for our robot. Each time we deploy, we keep recieving an error that I have pasted at the bottom of this post. We've followed all of the steps at https://github.com/WPIRoboticsProjec...Raspberry-Pi-2 and have copied over the shared libraries. Each time we deploy, it keeps saying that it can't instantiate files related to network tables. I'm sure that we have placed the shared libraries in the right folders and have deployed the project to the right folder, so do you know why this isn't working? I'm using GRIP 1.2 on Raspbian.
Thanks,
Jonathan
/usr//bin/java -Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError -jar '/home/pi/code/grip/grip.jar' '/home/pi/code/grip/project.grip'
Loading Dependency Injection Framework
Oct 15, 2016 3:58:43 PM java.util.logging.LogManager$RootLogger log
CONFIG: Configuration done.
CONFIG: GRIP Version: 1.2.0-5-g3a658db
platform: /Linux/arm/
Oct 15, 2016 3:58:45 PM edu.wpi.grip.core.GRIPCoreModule onThreadException
SEVERE: Uncaught Exception on thread Thread[main,5,main]
com.google.inject.ProvisionException: Unable to provision, see the following errors:
1) Error injecting constructor, java.lang.UnsatisfiedLinkError: no ntcore in java.library.path
  at edu.wpi.grip.core.operations.networktables.NTManager.<init>(Unknown Source)
  at edu.wpi.grip.core.operations.networktables.NTManager.class(Unknown Source)
  while locating edu.wpi.grip.core.operations.networktables.NTManager
    for field at edu.wpi.grip.core.Pipeline.ntManager(Unknown Source)
  at edu.wpi.grip.core.Pipeline.class(Unknown Source)
  while locating edu.wpi.grip.core.Pipeline
    for field at edu.wpi.grip.core.serialization.Project.pipeline(Unknown Source)
  at edu.wpi.grip.core.serialization.Project.class(Unknown Source)
  while locating edu.wpi.grip.core.serialization.Project
    for field at edu.wpi.grip.core.Main.project(Unknown Source)
  while locating edu.wpi.grip.core.Main
Caused by: java.lang.UnsatisfiedLinkError: no ntcore in java.library.path
	at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1864)
	at java.lang.Runtime.loadLibrary0(Runtime.java:870)
	at java.lang.System.loadLibrary(System.java:1122)
	at edu.wpi.first.wpilibj.networktables.NetworkTablesJNI.<clinit>(NetworkTablesJNI.java:57)
	at edu.wpi.grip.core.operations.networktables.NTManager.<init>(NTManager.java:50)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
	at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
	at com.google.inject.internal.DefaultConstructionProxyFactory$1.newInstance(DefaultConstructionProxyFactory.java:86)
	at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:105)
	at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:85)
	at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:267)
	at com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46)
	at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1103)
	at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
	at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:145)
	at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:41)
	at com.google.inject.internal.SingleFieldInjector.inject(SingleFieldInjector.java:54)
	at com.google.inject.internal.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:132)
	at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:114)
	at com.google.inject.internal.InjectorImpl$2$1.call(InjectorImpl.java:1016)
	at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1092)
	at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1012)
	at com.google.inject.internal.InjectorImpl.getInstance(InjectorImpl.java:1051)
	at edu.wpi.grip.core.Main.main(Main.java:43)
2) Error injecting constructor, java.lang.NoClassDefFoundError: Could not initialize class edu.wpi.first.wpilibj.networktables.NetworkTablesJNI
    for field at edu.wpi.grip.core.serialization.StepConverter.pipeline(Unknown Source)
  while locating edu.wpi.grip.core.serialization.StepConverter
    for parameter 0 at edu.wpi.grip.core.serialization.Project.initialize(Unknown Source)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class edu.wpi.first.wpilibj.networktables.NetworkTablesJNI
	at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:38)
	at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:62)
	at com.google.inject.internal.SingleMethodInjector.inject(SingleMethodInjector.java:84)
3) Error injecting constructor, java.lang.NoClassDefFoundError: Could not initialize class edu.wpi.first.wpilibj.networktables.NetworkTablesJNI
    for field at edu.wpi.grip.core.serialization.SocketConverter.pipeline(Unknown Source)
  while locating edu.wpi.grip.core.serialization.SocketConverter
    for parameter 2 at edu.wpi.grip.core.serialization.Project.initialize(Unknown Source)
3 errors
	at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1025)
2016: District Event Winner @ Columbus District Qualifier (PCH)
2016: Engineering Inspiration Award @ Peachtree District State Championship
2016: Tesla Subdivision Playoffs Appearance @ FIRST Championship
Unread 16-10-2016, 15:04
bankst's Avatar
bankst bankst is offline
FRC #0832 (OSCAR)
bankst is an unknown quantity at this point
Re: GRIP Deploy Not Working
I had this issue too. The Deploy page won't properly run GRIP, you have to use a custom script to do it. On this page it has this command:
$ env LD_LIBRARY_PATH=/home/pi/vision/grip:$LD_LIBRARY_PATH java -jar /home/pi/vision/grip/grip.jar /home/pi/vision/grip/project.grip
Replace any paths with the proper ones for your set up, and make sure you have the libntcore.so and libstdc++.so.6 in there. This worked for me, but I'm switching to straight OpenCV for other reasons. Hope that helps.
Unread 18-10-2016, 17:46
Jayd009's Avatar
AKA: Jonathan
Rookie Year: 2016
I tried that but now it can't create a JVM. I'm just going to run GRIP on the driver station and stream the camera through the RIO USB port. Maybe we can get openCV running on the Pi next season. Is there a guide you followed for getting it to work with Network Tables?
Unread 18-10-2016, 18:18
Jchau Jchau is offline
1414 - Programmer | Engineer
FRC #1414 (iHOT Robotics)
Rookie Year: 2015
Jchau is an unknown quantity at this point
I really recommend doing OpenCV and network tables. Here is a guide for integrating network tables. http://pynetworktables.readthedocs.io/en/latest/
Sent from my SM-N920G using Tapatalk
Unread 19-10-2016, 19:19
bankst's Avatar
FRC #0832 (OSCAR)
I recently finished up the OpenCV code for my Raspi 3, if you want to take a look, or copy it completely, here it is. I'll be updating it with a tuning window tomorrow, so keep an eye out for that. I'll admit, its definitely not the best code, but it works very well with little latency.
There are instructions in the README.md on the process I went through to install everything. I cannot recommend running this on anything but the Pi 3. I tried it on the Pi 2 and it took too long, and left me with a very low framerate. I can't imagine how the Pi 1 would handle it, if at all.
If you have any questions, please PM me. Even better, if you have any improvements, pull request me!
Unread 20-11-2016, 18:57
kmckay's Avatar
kmckay kmckay is offline
FRC #5401 (Fightin' Robotic Owls)
Rookie Year: 2015
kmckay will become famous soon enough
Having a similar problem. Are you saying the GRIP deploy window will never succeed on the pi (at least until GRIP is patched)? After the deploy operation, is GRIP ready to run on the pi?
Unread 21-11-2016, 10:35
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
AKA: Sam Carlberg
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
You need to set the "LD_LIBRARY_PATH" environment variable to have the directory you put the ntcore libraries. You can do this either by the method on the wiki:
$ env LD_LIBRARY_PATH=/home/pi/vision/grip:$LD_LIBRARY_PATH java -jar ...
or by setting it in the .bashrc file in your home directory by adding this line:
export LD_LIBRARY_PATH=/home/pi/vision/grip:$LD_LIBRARY_PATH
You can edit this file with "$ nano ~/.bashrc".
WPILib
GRIP, RobotBuilder
Unread 21-11-2016, 12:58
kmckay's Avatar
Rookie Year: 2015
Speaking on behalf of the amateur programmers, seeing this answer and others like it, I think I've found the problem.
I think we missed this line in the wiki guide:
"From the deploy window, click deploy. Once it's finished deploying just hit stop as GRIP will fail to run properly due to library issues."
We're supposed to get the errors when we deploy, its normal, we should ignore it, and continue down the wiki where we run GRIP from the command line using the "env". I understand this is an RTFM error on mine and others' parts, but it might eliminate some questions if this was highlighted a bit more in the wiki.
Correct?
Well, I did that, and from the command line I'm getting:
terminate called after throwing an instance of 'std::logic_error'
what(): basic_string::_S_construct null not valid
Unread 21-11-2016, 13:17
AKA: Sam Carlberg
Yeah, the wiki could be better.
Can you post the full stacktrace?
WPILib
GRIP, RobotBuilder
Unread 21-11-2016, 13:48
kmckay's Avatar
Rookie Year: 2015
Pardon my ignorance but Linux is not my first language, where can I find the full stacktrace?
Unread 21-11-2016, 14:02
AKA: Sam Carlberg
It's the entire output you got when you tried to run it from the command line, not just that one line. There should be a lot of lines that look like
"at edu.wpi.grip....(123)"
WPILib
GRIP, RobotBuilder
Unread 21-11-2016, 14:09
alst alst is offline
Programming Mentor
AKA: Alan
FRC #0830 (RatPack)
Rookie Year: 1830
alst is an unknown quantity at this point
That's not a Java stack trace (it appears to be something in libstdc++), so I doubt there's anything else. I would recommend double-checking and making sure the correct libstdc++ is in the same folder you have in LD_LIBRARY_PATH, but I'm not really familiar enough with GRIP, so I can't offer much more than that.
Unread 21-11-2016, 14:41
kmckay's Avatar
Rookie Year: 2015
I will get the full output when I get home.
I definitely have the files linked to on the wiki there. Only difference is that I ftp'd them there and not scp. The only reason I can think that might make a difference is if the file permissions don't set the same.
Unread 21-11-2016, 18:04
kmckay's Avatar
Rookie Year: 2015
I'm using a RPi3, putty ssh via a peer to peer. I do not have a RoboRio on the network right now.
I did alter the start_vision.sh from the wiki to include a -b to run in the background. Without it, I found the mjpg_streamer sat there and grip never started.
Any help would be appreciated.
Combined Vision Starting Script
Start mjpg streamer
enabling daemon modeforked to background (776)
/home/pi/vision/start_vision.sh: line 5: pause: command not found
Starting GRIP processing
pi@pulsatrix:~ $ Nov 19, 2016 6:28:58 PM java.util.logging.LogManager$RootLogger log
CONFIG: GRIP Version: 1.5.0-rc3
2016-11-19 18:29:02.026:INFO::main: Logging initialized @3761ms
Edit: Seeing the pause error, I changed that line to read-p "--" and just counted to 5 before continuing. Same result.
Edit2: pulsatrix is the name of the pi. Its the species name of the spectacled owl
Unread 21-11-2016, 18:46
AKA: Sam Carlberg
That's bizarre. I'll see if I can reproduce this tonight. If not, you can use 1.5 and generate OpenCV code to run on the Pi without needing to deploy GRIP
WPILib
GRIP, RobotBuilder
