Go to Post You know it’s a tough game when you see a bearing on the floor. - D.Allred [more]
Unread 15-10-2016, 20:43
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Re: 5010 T-Shirt Launcher Prototype
Originally Posted by GeeTwo View Post
If you're planning to use it during basketball season, either you're using too small of a solenoid valve or you're going to have shirts hitting the roof of any normal-sized gym. We launched a t-shirt over the top of our football stadium last night with less than 60psi in the secondary tank, using a 3/4" diameter solenoid valve.
Barrel length and cylinder seal could also be effecting their ranges. If the solenoid is the issue, though, longer barrels should do the trick
It isn't shiny enough.
