Go to Post "No wheels, no problem, we can fix it in programming." - clean399 [more]
Unread 15-10-2016, 20:43
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Position and velocity PIDControllers using same encoder
Originally Posted by GeeTwo View Post
Again, it's a matter of weighing the ugly, but perhaps you could free the encoder you aren't using (if I understand correctly, setting the variable(s) referencing it to null and possibly running garbage collection will accomplish this), then initiate the new one.
If I were never going to use them at the same time, this would probably work - but, as mentioned earlier in the thread, the notion is to run a cascading control loop on a turret where the position controller outputs to a velocity controller using the same encoder.
"The breakfast of champions!"
