Go to Post Gracious Professionalism at its finest - Competing like CRAZY on the field, then working together like professionals off the field to make these events the best they can be for everyone involved. - Stu Bloom [more]
Unread 08-10-2016, 16:57
Jayd009's Avatar
Jayd009 Jayd009 is offline
AKA: Jonathan
FRC #4468 (Fernbank LINKS)
Rookie Year: 2016
Jayd009 is on a distinguished road
Gyro Drift
Hello everyone,
My team (Fernbank LINKS) is trying to use an Analog Devices gyro on our robot for GRITS (October 22). We have been able to attach it to our robot, but every time we test it, the angle increases when the robot isn't moving, which is messing with our autonomous program. I don't know the exact model of the gyro, but I have posted a picture of it below. We have been wiring our gyro in the rate pins, and we have been using the correct cable. Does anyone know how to fix this? If not, does anyone have a different model that they would be willing to sell us?
Thanks,
Jonathan Daniel
2016: District Event Winner @ Columbus District Qualifier (PCH)
2016: Engineering Inspiration Award @ Peachtree District State Championship
2016: Tesla Subdivision Playoffs Appearance @ FIRST Championship
Unread 08-10-2016, 20:29
bdaroz's Avatar
bdaroz bdaroz is online now
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
Re: Gyro Drift
We don't have that model on our bot (we have the one that came w/ First Choice), but I wonder -- is there a calibration routine that you may not be running?
I know with the FC one we have to have the bot powered up and still for at least 20-30s stationary and then trigger the calibration (which takes a few seconds) and then the drift drops to < 0.1 deg/sec and usually < 1 deg/min. (I can also say if the robot isn't still, or if it's calibrated too quickly the drift is higher, sometimes severely so.)
Unread 09-10-2016, 00:58
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: Gyro Drift
This looks like the gyro used to be included in the KOP. We used that gyro in 2014 and 2015, and it worked well enough to be used for field oriented driving throughout the match, but it does drift faster than some of the other options.
When the robot code initializes, the gyro gets calibrated and the robot must not be moving at all during this time.
It is possible that the gyro is damaged, possibly by ESD or impacts. I believe we damaged two of these gyros while crossing defenses in 2016, although I don't know for sure what caused them to fail. They started drifting unpredictably, so we decided use a NavX instead, which worked very well. I have heard good things about the WCP Spartan board as well, but I have not used it.
Unread 17-10-2016, 12:50
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: Gyro Drift
Please see this thread for an alternative.
