Re: No Robot Code
Have you tried looking for any messages that appear when attempting to run the code manually over ssh?
Re: No Robot Code
Just checking given all the things you did list that you've tried...
If you reimaged the RoboRIO, did you reinstall the Java Runtime on the RoboRIO? |
Re: No Robot Code
I also had this happen to me. Here is a link to the thread.
One thing I found(I believe it works) is to start over with the code. Deploy a basic FRC WPILIB example and to add one piece at a time and find where the code errors out. |
Re: No Robot Code
Looks like eclipse is able to connect but not the driver station. Double check that your team number is correct in eclipse preferences > WPILib (if not, fix it and redeploy) and that the team number is also correct on the driver station.
