Go to Post Age should not be a speed bump to creativity. - Greg Needel [more]
Unread 17-10-2016, 16:10
philmharner philmharner is offline
FRC #5243
philmharner is an unknown quantity at this point
No Robot Code
When we try to deploy our robot code, it says "Build Successful". In the FRC Driver Station, however, says there is no robot code.
-Communication light is Red on the roborio and the driver station
Code can be found:
https://github.com/Team-5243/Basketb...e/master/robot
Build Log:
Buildfile: C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\build.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\build
[delete] Deleting directory C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\dist
compile:
[mkdir] Created dir: C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\Robotics1/wpilib/java/current/lib/WPILib.jar:C:\Users\Robotics1/wpilib/java/current/lib/NetworkTables.jar: to build
[javac] Compiling 7 source files to C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\build
jar:
[echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
[mkdir] Created dir: C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\dist
[mkdir] Created dir: C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\build\jars
[echo] [athena-jar] Copying jars from C:\Users\Robotics1/wpilib/java/current/lib/WPILib.jar:C:\Users\Robotics1/wpilib/java/current/lib/NetworkTables.jar: to build/jars.
[copy] Copying 2 files to C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\build\jars
[jar] Building jar: C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\dist\FRCUserProgram.jar
get-target-ip:
[echo] Trying Target: roboRIO-5243-FRC.local
[echo] roboRIO found via mDNS
dependencies:
[echo] roboRIO image version validated
[echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s...ller-java-only
[sshexec] Connecting to roboRIO-5243-FRC.local:22
[sshexec] cmd : test -d /usr/local/frc/JRE
deploy:
[echo] [athena-deploy] Copying code over.
[scp] Connecting to roboRIO-5243-FRC.local:22
[scp] done.
[sshexec] cmd : killall -q netconsole-host || :
[scp] done.
[echo] [athena-deploy] Starting program.
[sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
[sshexec] cmd : sync
BUILD SUCCESSFUL
Total time: 9 seconds
Things we have tried:
--Updating Roborio firmware
--Tried with multiple roborios
--Tried with last year's code (worked last year, also included more sensor code, no change)
--Tried redeploying easily 10 times
After reading Ozrien's post in https://www.chiefdelphi.com/forums/s...hreadid=141652
--we tried to put a joystick in our last port (and in both ports). Did nothing.
Unread 17-10-2016, 16:54
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Re: No Robot Code
Have you tried looking for any messages that appear when attempting to run the code manually over ssh?
Unread 17-10-2016, 17:13
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
Re: No Robot Code
Just checking given all the things you did list that you've tried...
If you reimaged the RoboRIO, did you reinstall the Java Runtime on the RoboRIO?
Unread 17-10-2016, 18:04
GoldenGollem's Avatar
GoldenGollem GoldenGollem is offline
Java Programmer
FRC #2509 (Hutchinson Tigerbots)
Rookie Year: 2015
GoldenGollem is an unknown quantity at this point
Re: No Robot Code
I also had this happen to me. Here is a link to the thread.
One thing I found(I believe it works) is to start over with the code. Deploy a basic FRC WPILIB example and to add one piece at a time and find where the code errors out.
GoldenGollem -Hutchinson Tigerbots 2509
2015 - Mini-MN Regional 2nd Place Finalist
2016 - Mini-MN Regional 1st Place Finalist
Unread 17-10-2016, 18:14
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: No Robot Code
Looks like eclipse is able to connect but not the driver station. Double check that your team number is correct in eclipse preferences > WPILib (if not, fix it and redeploy) and that the team number is also correct on the driver station.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 18-10-2016, 00:14
Re: No Robot Code
Are you sure you are running to code in github? There are 9 source files in github, but your build log only shows 7.
Unread 19-10-2016, 13:51
FRC #5243
Re: No Robot Code
Found the issue.
The Shoot command activates the solenoid subsystem, waits 5 seconds, and then deactivates it. The issue?
We put
private SolenoidSubsystem SS = new SolenoidSubsystem(); as the attribute, instead of leaving it
private SolenoidSubsystem SS;
and then initializing it in the initialize method.
Unread 20-10-2016, 12:25
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Re: No Robot Code
Found the issue.
We put
That doesn't explain why the communication light was red. Are you sure you didn't mean the robot code light when you said that in your original post?
