Go to Post Shouldn't we be encouraging exploration instead of repeatedly beating it with a stick? - Mike Soukup [more]
Unread 17-10-2016, 22:23
Stephen41 Stephen41 is offline
Stephen41 is an unknown quantity at this point
Screw Size for Tetrix Motor
I have a question, what is the size of the screw used to connect a shaft encoder to a Tetrix motor?
Unread 18-10-2016, 04:21
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Screw Size for Tetrix Motor
I don't believe that there is a shaft encoder for the Tetrix Motor. You might be thinking of the Andymark Neverest motor( it's quite a bit larger) which has a hall effect encoder mounted to the back of it. Any small Phillips head screw driver should be able to undo the two screws attaching the hall effect encoder on the back.
Facebook
Unread 18-10-2016, 10:19
mmkkrk mmkkrk is offline
mmkkrk is an unknown quantity at this point
Screw size is 3mm.
