Go to Post Dave, you're going to have quite the motor pool on Mars. :D - skimoose [more]
Unread 17-10-2016, 23:52
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is online now
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Rev More Board and Nav-X
Has anyone paired a Rev More Board (v2.0) and a Nav-X MXP Robotics Navigation Sensor together with the RoboRio? We are looking at a offseason project that requires a good navigation board and more than 10 PWM slots.
We already have the Nav-X board.
Any suggestions, thanks in advance.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 18-10-2016, 00:30
Re: Rev More Board and Nav-X
The "Digital I/O" of the NavX-MXP are the multiplexed PWM ports. So the NavX alone may do what you need.
Unread 18-10-2016, 00:31
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
The navX breaks out all the pins on the MXP, just like the More Board does. If you are going to mount the navX on the roboRIO, it is not possible (nor is there really any reason) to use a More Board.
It is possible that I am misunderstanding what you are trying to do.
Unread 18-10-2016, 02:05
REVving up for a new season
FRC #2848 (All-sparks)
This is the reason that we have an MXP cable. It allows you to mount the moreboard to the roboRIO and then use the cable to mount the navX anywhere on the robot you need or want it to be.
http://www.revrobotics.com/extension-cable/
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 18-10-2016, 08:32
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Do you need a good navigation board or good navigation? If the later, you could use an external sensor.
Unread 18-10-2016, 10:05
AKA: Clint Brawley
FRC #0364 (Fusion)
I'm trying to determine if the More Board V2.0 with it's "MXP pass-through connector" will allow us to place the NAV-X on top of it, effectively sandwiching the More Board between the roborio and Nav-X board. Or is the cable required?
Thanks
Clint Brawley
USAF 1992-2013
Unread 18-10-2016, 10:24
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
The More Board will not give you any additional PWM outputs than the Nav-X board does. They're the same signal and break-out the signals from the RoboRIO's MXP port directly to the 3-pin PWM ports. In other words, both (More & Nav-X) break-out the already present 10 PWM outputs, and neither expand 10 PWM outputs.
I think the Nav-X does what you need it to do.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 18-10-2016, 10:43
AKA: Clint Brawley
FRC #0364 (Fusion)
Thanks Ryan!
Clint Brawley
USAF 1992-2013
Unread 18-10-2016, 19:43
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
FWIW, the NavX can be connected via usb to the roboRio, allowing for use of the NavX sensors and a different expansion board.
Unread 18-10-2016, 19:54
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Also, the navX-Micro is a lower-cost version of the navX-MXP which leaves off the MXP IO Expansion. navX-Micro also connects via USB (or I2C) - so that's another option to consider.
