Go to Post I just think that if we are going to have rules intended to level the playing field, they shouldn't hurt teams that put the effort in to go the extra mile. - Dave Scheck [more]
Unread 19-10-2016, 00:09
Starwarsguy2's Avatar
Starwarsguy2 Starwarsguy2 is offline
Too many robots, not enough time
AKA: Jake Morris
FRC #0316 (LuNaTeCs)
Rookie Year: 2015
Starwarsguy2 is a splendid one to beholdStarwarsguy2 is a splendid one to beholdStarwarsguy2 is a splendid one to beholdStarwarsguy2 is a splendid one to beholdStarwarsguy2 is a splendid one to beholdStarwarsguy2 is a splendid one to beholdStarwarsguy2 is a splendid one to behold
LabVIEW reentrant VIs
Team 316 has discovered a very recent problem with our potentiometers. We use LabVIEW to program the robot and have two pots on the robot, one for our shooter angle, and one for our pickup arm. We are only concerned with the value of the shooter angle pot through. When we read those two values with two separate VIs, it pulls the same values. These values fluctuate wildly and I thought that I had found the solution, as described in this thread . However, when I tried the suggested solutions, it did not work. Even after making the VIs reentrant, I still made new copies of the code with a new name, which also did not work. The behavior of the values usually goes like this: 0 for a split second, two consecutive values that make sense (probably the actual values of the pots), and then 1 for a split second. Wash, rinse, repeat.
This greatly confuses our PID for the shooter angle and it merely moves back and forth eventually getting stuck in one position. (Usually fully forward, a position that wouldn't even shoot the ball at all). I was wondering if the Delphi community had any other solutions. I have made copies, made the VIs reentrant, and even unplugged the pickup arm pot. However, the code still returns values as described above.
Thank you in advance.
Too much robots is still not enough.
Unread 19-10-2016, 08:44
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: LabVIEW reentrant VIs
Can you post the VI/Code? Also, are you choosing "Preallocated clone reentrant execution" or a different option?
Unread 19-10-2016, 16:45
AKA: Jake Morris
Rookie Year: 2015
I am choosing "Preallocated clone reentrant execution". I'll upload the code as soon as I can, should be late sometime tonight. I barely have enough time to post this now. Thanks!
Unread 20-10-2016, 00:05
wt200999's Avatar
wt200999 wt200999 is online now
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
One thing to note when it comes to reentrant VIs on LabVIEW Real-Time (when deployed to roboRIO) is that none of the LabVIEW debugging tools are available, so you either need to make a copy or use a different method to debug. See the note here.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 20-10-2016, 08:01
There should be no problem reading the pots with the non-reentrant VI. Setting it to reentrant will have no effect on the result, but will allow for the two calls to proceed in parallel - up to the point where there may be another reason for them to take turns.
What I'd suggest you do is to drop charts on the panel of your VI and wire the output of the pot to the charts. Run the VI and see if moving pot A affects the chart. See if moving pot B affects the chart. If you are receiving 0's, they may be due to a wiring connection rather than reading the wrong pot.
While running, wiggle the wires and see if you can locate a connection issue anywhere along the cable.
Please let us know what you find.
Greg McKaskle
Unread 20-10-2016, 23:41
AKA: Jake Morris
Rookie Year: 2015
Thank you all very much for your replies. However, the issue turned out to be much more grave. The 5V analog in rail was only supplying a maximum of .3 volts ! We tried our hardest to clean out the RoboRIO but the problem still persisted. Sadly, the mentors are thinking that this is a bad RIO. It went through two rough seasons, so it had to go eventually. (But it just had to die 2 days before a competition ) We are borrowing a RIO from another team in the meantime. Again, thanks for all the help, and if you have any suggestions to bring a RoboRIO back from the dead, they'll be greatly appreciated.
Jake
Unread 21-10-2016, 09:39
The most reliable way is to contact NI for repair/replacement. AndyMark may also be a good place to start if it was purchased there.
Greg McKaskle
