Go to Post Step 1: Get Drill Step 2: Insert 1/2"-1" bit into drill Step 3: Drill Those Speed Holes! - Adam Richards [more]
Unread 10-20-2016, 02:37 PM
mkmeral mkmeral is offline
FRC #4191
mkmeral is an unknown quantity at this point
Communication from Arduino to Roborio
Hello everyone,
I have two questions actually. First of all, is it illegal to use more than 1 custom circuit in the robot, is there a limit? Secondly, I need to send information from arduino to roborio (we'll have custom circuit and custom sensors that do not connect to roborio directly) How do i do it without buying any parts, because I'm in Turkey and it'll take 3-4 weeks for them to arrive here.
Thanks
Unread 10-20-2016, 02:57 PM
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Re: Communication from Arduino to Roborio
To answer the first part of your question: in the past there has not been a limit on the number of custom circuits in the robot, other than that all other rules must be followed such as what the circuit is used for and the overall cost limits.
As always in FRC, past rules are no guarantee of future rules. But on this one you are probably safe that it will not change.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 10-20-2016, 03:05 PM
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Captain
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
For your second, you can hook up the Arduino to the roboRIO I2C bus. In this setup, the Arduino has to be a slave device. You can do this with just wires.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 10-20-2016, 03:08 PM
Volunteer, WPILib Contributor
no team (Waiting for 2021)
One option for connection is to directly hook up the arduino over usb to the roborio. This provides power, and you can use a serial connection to communicate between the roborio and the arduino. I've done this most often in the past because it's a single wire and fairly easy to program.
Team 4488 - Mentor 2013-2016
Unread 10-22-2016, 07:36 AM
FRC #4191
How do you do it? By using RXTX? What are names of the ports of Roborio (for example "COM1" etc for windows). When i tried it, it broke the roborio's comm.
Unread 10-22-2016, 02:56 PM
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
The Arduino should either be /dev/ttyACM0 or /dev/ttyUSB0.
Unread 10-23-2016, 06:00 PM
bankst's Avatar
bankst bankst is offline
FRC #0832 (OSCAR)
bankst is an unknown quantity at this point
I've had great success doing one-way communication with I2C on the cRIO, but I've never tried two-way or done any on the RoboRIO, but I do believe its very similar. Here is my Java code for getting data from the Arduino with a cRIO. I'll put the arduino code on GitHub later tonight and upload it to a new repo. If you have any questions please PM me.
