Go to Post Yes there are a lot of problems that will pop up solving the problem, but thats the reason we do engineering for. - Arefin Bari [more]
Unread 10-18-2016, 11:34 AM
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 is on a distinguished road
Prototyping / Building efficiencies
My goal this year it to make my team more efficient at prototyping and building . To do this we are going through are shop and creating some new jigs / fixtures to are mill and other tools. Here is a list of some of things we are doing
1) plate fixture for the mill
2) Side tables with stop blocks for the chop saw
3) Alignment plate for the mill
This got me wondering what other teams do to increase efficiencies. If you would not mind please share what has worked for your team
2015 Midwest Regional Finalist
2015 Central Illinois Regional Winner
2015 Newton Division Finalist
2015 Newton Quality Award
Unread 10-18-2016, 11:42 AM
Doug G's Avatar
Doug G Doug G is online now
Coach / Teacher
FRC #0701 (Robovikes)
Re: Prototyping / Building efficiencies
Yeah, I feel the same around our shop also... I'm really hoping to make one of these fixture plates for our new CNC before build season...
https://www.youtube.com/watch?v=VL7t87Bpl08
Unread 10-18-2016, 11:49 AM
Bpk9p4's Avatar
FRC #1756
i am actually making a couple of those tonight for are mills and CNC. I will let you know hit goes and how painful it is. if it works out well we can share are CAD file
Unread 10-18-2016, 11:52 AM
RoboChair's Avatar
AKA: Devin Castellucci
We don't prototype with mills and lathes unless 100% needed. We prototype with hand tools, wood, and drills. It's faster and gives us info quickly so we can then refine our tests with a better design.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 10-18-2016, 12:25 PM
Doug G's Avatar
Coach / Teacher
Totally agree... and that is one significant area our team needs to improve on, which is true of a lot of teams out there, is building a prototype worth drawing conclusions from. And sometimes, that requires milling or CNC'ing some key components. I think that is a significant factor in what makes a great team stand apart from a good team. To have the experience and resources to make a really good prototype that leads to a great design which can then get iterated a half dozen times in the span of 6-8 weeks is priceless. Just another reason we watch the poofs, circuits, wranglers, simbots, OP, 'nauts, spartans, etc... with such awe.
Unread 10-18-2016, 01:41 PM
Bpk9p4's Avatar
FRC #1756
In the past we have done most of are prototyping in wood however we struggle how with how far to take it with wood. To what level do you keep working in wood?
Unread 10-18-2016, 01:55 PM
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
One thing I would advise making is depending what type of material you use for your robot, making a jig in case you need to lighten up your robot. We used primarily 2" width pieces on our robot in 2016, so 2" x 1/4" flat stock, 2" x 1" rectangle tubing, etc. so we created something we could clamp on and make perfectly center holes. It allowed us to maximize the amount of holes to reduce the amount necessary and effectively. We had some areas we wanted to remove more weight than others due to trying to lighten our arm and robot at the same time.
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 10-18-2016, 02:37 PM
Chris is me's Avatar
AKA: Pinecone
"unless 100% needed" happens at least once a year for me. There are some mechanisms you really do need precise information on geometry or some near-production quality feature.
Unread 10-20-2016, 09:51 AM
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
Here are some jigs that we have used very successfully in the past. The first is steel metal plates with the mounting hole locations for the BB P60, and versa planetary gearboxes in all their configurations. These make it super easy to quickly mount these boxes to anything. Even plywood for prototyping. The second jig is a custom clamping box we made to make drilling cross ways through 80/20 extrusions super easy. It has a hardened steel insert that when installed allows a 1/4 inch bit in for clearance on 1/4 20 hardware, and when removed allows a larger bit for bolt head clearance so that the head of the bolt is flush with the surface of the 80/20.
I believe that 80/20 is one of the best prototyping materials there is. We have used it very successfully for quick building chassis, and prototyping fairly quick and easy yet precise shooter and claw mechanisms. it is great.
ID:	21196  Click image for larger version
ID:	21197  Click image for larger version
ID:	21198  Click image for larger version
ID:	21199  Click image for larger version
FRC Rebound Rumble | Ultimate Ascent | Aerial Assist | Recycle Rush | FIRST Stronghold | FIRST STEAMWORKS
FLL Senior Solutions | Nature's Fury | Trash Treck | Animal Allies
Unread 10-20-2016, 05:07 PM
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
One can get pretty far with wood!
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 10-20-2016, 05:59 PM
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Yup, I'd say wood works pretty well.
Unread 10-21-2016, 10:16 AM
Bpk9p4's Avatar
FRC #1756
I really like your ideas. I am going to make that BB D60 jig this weekend. Any chance you would care to share a drawing of that so i could reproduce it?
I just made are plate jig this week. We tried it out yesterday and was able to make gussets really fast and accurately
Unread 10-23-2016, 01:09 PM
DonRotolo's Avatar
Back to humble
FRC #0832
Pink Foam.
We use foam to get the dimensions and layout of things right. It's inexpensive, easy to work with and light. It is not strong though...
